Infinity Perfect 6.1 Problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60342
Printed Date: April 28, 2024 at 4:56 PM
Topic: Infinity Perfect 6.1 Problems
Posted By: Teamrf
Subject: Infinity Perfect 6.1 Problems
Date Posted: July 29, 2005 at 6:30 PM
I have had problems with these speakers and I've read that others have had problems too. I have these speakers hooked up to a Eclipse 4 channel amp. The amp is fine without the x-over. When I put in the x-over it shuts the amp down completely. I don't know what the issuse is. These are brand new speakers and I don't know why I'm having this problem. I took them out and put in some different speakers and they worked fine. I know the problem is coming from the x-over but I don't know what is going on.
------------- ~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: DYohn
Date Posted: July 29, 2005 at 6:32 PM
Sounds like the crossover is shorted. Return time. ------------- Support the12volt.com
Posted By: Grkinstall
Date Posted: July 29, 2005 at 6:56 PM
use a test metter and test all your ohms and that there isn't a short in line
Posted By: blg748
Date Posted: July 29, 2005 at 10:23 PM
Teamrf: Im very sorry if this is off topic. But i have Infiniy Perfects 6.1s and i JUST BOUGH A 98 ACCORD 2Door and noticed u have a 01 which is same model. WHERE AND HOW DID U FIT UR comps in the front doors ?
Posted By: Teamrf
Date Posted: July 30, 2005 at 5:09 PM
I have them in the factory hole.
Posted By: Teamrf
Date Posted: July 30, 2005 at 5:12 PM
I returned them and I just got them back. when I hook up the speaker directly to the amp everything is fine. When I put the crossover in line it shuts down. Do the speakers need the tweeters hooked up for them to work properly?
Posted By: Teamrf
Date Posted: July 31, 2005 at 4:31 PM
Does anyone have the remedy for this problem?
Posted By: DYohn
Date Posted: July 31, 2005 at 6:06 PM
You tried a new crossover set and it does the same thing? I assume you are connecting one crossover to one amplifier channel? Also I assume you are connecting the crossover to the amp and then the speakers to the crossover and you are not connecting them in parallel? Try this: connect just the crossover and no speakers. Power on the amp. If it goes into protection mode, there is either still an issue with the crossover or the amp is shot. ------------- Support the12volt.com
Posted By: Teamrf
Date Posted: August 02, 2005 at 11:07 PM
Ok but the amp only shuts down at medium to high volumes. Its not going into protect..it shuts down. ------------- ~The Rookie~
Posted By: DYohn
Date Posted: August 02, 2005 at 11:10 PM
Then I bet your gain is way too high. ------------- Support the12volt.com
Posted By: geepherder
Date Posted: August 03, 2005 at 9:12 AM
That's gotta be it. Back the gains off until the problem goes away.
------------- My ex once told me I have a perfect face for radio.
Posted By: Drewt
Date Posted: August 03, 2005 at 2:40 PM
ah, yeah, you should have tweeters hooked up....that would help
I'm trying to think right now if not having tweeters hooked up would cause the amp to go into protect, but my brain isn't working today...
-Drew
Posted By: Teamrf
Date Posted: August 03, 2005 at 6:32 PM
The gains are properly set. They aren't too high. I guess that having the tweeters are suppose to be hooked up. Because they aren't hooked up but I don't know if that would throw anything off and cause the amp to shut down completely.
Posted By: DYohn
Date Posted: August 03, 2005 at 7:14 PM
Having the tweeters disconnected should not cause any issues. I suggest you take your system in to a professional shop in your area and have them look at it. ------------- Support the12volt.com
Posted By: Teamrf
Date Posted: August 05, 2005 at 5:45 PM
**Insulted** I am a professional, but unfortunately I haven't seen this problem before. I have never had a problem out of Infinity until installing it on my own vehicle.
Posted By: 03taurus
Date Posted: August 05, 2005 at 8:01 PM
https://manuals.harman.com/INF/CAR/Owner%27s%20Manual/KAPPA%20PERFECT%206-1%20om.pdf Have you checked the jumpers on the tweeter level? Maybe you can change this and it may work. Or maybe you have to take off all the jumpers to run a no tweeter set-up.
Posted By: Teamrf
Date Posted: August 09, 2005 at 8:29 PM
So you think the tweeter not being present has an effect on the amp shutting off? ------------- ~The Rookie~
Date Posted: August 11, 2005 at 8:13 AM
No.
