Car wont work with factory HU out
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62975
Printed Date: May 28, 2024 at 2:31 PM
Topic: Car wont work with factory HU out
Posted By: HICKMANAE3
Subject: Car wont work with factory HU out
Date Posted: September 20, 2005 at 3:13 PM
Where can i get a list of precise cars that will not work when the factory HU is removed and also what is the name of the kit that you have to use in order to hook up the factory Hu somewhere in the car so the aftermarket HU will work. Also is there any way to bypass having to install the factory HU? ------------- No security system can beat the tow truck :(
Posted By: outtaluck72
Date Posted: September 20, 2005 at 4:23 PM
to my knowledge there is no vehicle out there that will not operate or run without the radio. do you have any examples of these vehicles or were you told this second hand? even the pain in the butt class 2 and GM LAN vehicles run without the radio. even the Toyota Prius will run without the radio, and alot of info goes through the radio.
Posted By: kgerry
Date Posted: September 20, 2005 at 4:24 PM
define "will not work"... i cant think of a single vehicle where the vehicle will not start with the radio removed.....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: sneakycyber
Yes you can use an OEM-1 by-pass from metra it plugs into the factory harness and allows you to connect aftermarket. We carry them on our website. You can also use our website to find out what vehicles take the by pass. -------------
Date Posted: September 20, 2005 at 4:30 PM
PS. as with the other guys said there are no vehicles that will absolutley not run you just loose some features such as door chime and onstar.
Posted By: redpeppers
Date Posted: September 21, 2005 at 12:45 AM
some older jags will cut off fuel pump when radio is removed but there are very few and they r older.........
------------- Where theres is a wire there's a way.
Posted By: Velocity Motors
Date Posted: September 21, 2005 at 7:59 AM
This may help: https://www.velocitymotorsport.com/install_notes/OBDII.htm------------- Jeff
Posted By: uz2bauto
Date Posted: September 21, 2005 at 9:45 PM
i have done tons and tons of 00+ cavaliers and i use the 70-2003 or 70-2002 ( i forget which, i don't install anymore ) and the only thing that i know that is affected is the damn dinging out the speaker lol. i did hear of some people messing up a couple guage clusters or something, dunno if it was just installer neglegence though. input? ------------- paint and body
"semi-professional"
Posted By: auex
Date Posted: September 21, 2005 at 9:50 PM
I wonder if there is a list of vehicles that won't work with the engine taken out??? J/K.
There really isn't any type of vehicle that won't function without the factory radio. Some things may cease to work like chimes or onstar but who cares, that is why they make adapter harnesses and chime modules.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: gus1
Date Posted: September 22, 2005 at 2:08 AM
I know the new VW Jetta (MKV) won't start with the headlight switch removed for some strange reason..... but the radio? Doubt there are any...
Gus
------------- Wherever I go, that is where I end up......
Posted By: audiobliss69
Date Posted: September 22, 2005 at 6:06 PM
Man, that sure doesn't make much sense.
------------- Pioneer Premier DEH-P860MP
Boston Acoustic RC520
Posted By: hoaxs
Date Posted: September 22, 2005 at 7:44 PM
yeah newer cars with onstar and other special features. but i've heard of people relocating stock hu under the seat or tuck away under the dash for the oem options. ------------- Hurry get me a steel hanger, elec tape, zip ties, a monkey and a snorgle. trust me i've ran wires with less
