speaker box for 98 chevy extended cab
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63649
Printed Date: June 09, 2024 at 11:25 PM
Topic: speaker box for 98 chevy extended cab
Posted By: chevyjr73
Subject: speaker box for 98 chevy extended cab
Date Posted: October 02, 2005 at 3:30 PM
does anyone know if a subwoofer box will fit behind the seat in a 98 chevy truck extended cab? the space behind the rear bench seat looks very small. thanks.
Posted By: Blowntweeters
Date Posted: October 02, 2005 at 3:34 PM
you can put a box under the rear set. what type of sound are you looking for ?
------------- 1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Date Posted: October 02, 2005 at 3:42 PM
i already put in an aftermarket deck and new front door speakers. i just wanted a little more bass nothing really loud or anything
Date Posted: October 02, 2005 at 3:56 PM
look for boxes vehicle specific for your truck 1 12" sub will do just fine. i would recommend a infinity kappa perfect and a small class d mono block amp.
Posted By: arrow12
Date Posted: October 07, 2005 at 10:15 PM
you might be able to fit 6x9s in pre fab boxes. they are relatively small and can pack a good punch with a good amp.
------------- That's my opinion. Take it, leave it, or correct me.
Posted By: auex
Date Posted: October 07, 2005 at 10:17 PM
A self powered bass tube might be your solution. I hate these things but they sound decent in the trucks.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: October 07, 2005 at 10:23 PM
do you think they would fit under the seat? i was looking at a bazooka tube at circuit city. they have a 100 watt amplified tube with 8 inck woofer for about $140. would rather have a separate woofer and amp but dont really see a good place to put the sub.
Posted By: tcss
Date Posted: October 08, 2005 at 12:26 PM
Jl makes two differant " stealth boxes" for that truck. One is a single 10 the other is dual 10s. A little pricey, but they fit perfectly and save you the expense of designing and building the box.
------------- There is no such thing as free installation!
Posted By: avidangler
Date Posted: October 08, 2005 at 1:13 PM
Q Logic makes a sealed box to fit under the rear bench seat of your truck - I have a 96 extended cab and am probably going to buy one for my truck. The box will hold a 10" driver with a maximum driver mounting depth of 5 7/8". They also make a box for the passenger side of the rear seat if you wanted a pair of 10's - you would have to remove the factory jack and holder to make room for the box.
I saw one at a local shop for $250 and it looked like it was pretty well constructed but www.SoundDomain.com has the same thing for $170. The box has an ABS trim panel on the front edge that is colored to match the interior.
Date Posted: October 08, 2005 at 2:15 PM
Forgot to say that on CarDomain's site, they state the box is made from ABS plastic but that must be a mis-print as Q Logic states on their site that the unit is made from 100% 5/8" MDF enclosure construction and 3/4" MDF panel for the driver mounting panel with Dado groove and miter joint design for ultimate strength.
Here's the Q Logic site - https://www.qlogic.ws/2003/home/ - select Chevrolet under Q customs. The model# for the 96-98 extended cab is QL-C1GMX110DA for the drivers side and QL-C1GMX110PA for the passengers side.
Date Posted: October 08, 2005 at 2:24 PM
Sorry, if you go to SoundDomain.com first you then have to click on CarDomain to enter their car stereo area - confusing eh?
Posted By: ksw870
Date Posted: October 10, 2005 at 6:27 PM
I got a 2 12" downfire box for that style of truck...good box too. Too bad shipping would be a fortune.
