is this too much power?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64325
Printed Date: May 23, 2024 at 12:38 PM
Topic: is this too much power?
Posted By: lilbenny
Subject: is this too much power?
Date Posted: October 13, 2005 at 7:39 PM
i want to run 2 10w6v2's and 2 500/1 amps both made by JL AUDIO... the place i was going to get it installed told me its over kill and ill blow my subs, i also heard this from a friend... but another forum member (rx8club.com) told me its better to overpower then underpower subs and that it wouldnt be as good... What are your guys input? i guess ill call JL tomorrow and ask for thier opinion too....
Posted By: forbidden
Date Posted: October 13, 2005 at 10:14 PM
As some of us are also on that forum I'll offer my .02. You can overpower a sub all day long and not blow them provided you do not send a clipped signal into them and you do not play them for extended periods of time. A subwoofer must be allowed to cool. No cool with uber amounts of power releases the magic smoke in the sub that makes it work.
By the same token you can also underpower a sub, here however is where clipping is much more of a problem. This causes a loss of controlled motion of the driver and builds up excess heat until again the magic smoke that makes it work is released.
Ignore calling JL, all the advice you need is right in front of you on this forum or the RX8 forum. Before I went with a dual amp system for 2 subs in that small trunk (and I know every nook and cranny of that p***k), I would do a single amp system only. Why? Less space taken up, less install time, less wiring used, EASIER to set the levels properly (you don't have to worry about one amp not matching the other). Need more info, post it up and one of the old farts like me might answer it for you.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: lilbenny
Date Posted: October 13, 2005 at 10:38 PM
hmm so you suggest 2 amps? lol..
Posted By: veovius
Date Posted: October 14, 2005 at 2:46 AM
Oh god, don't ask rob to do another RX8 lmao
Date Posted: October 14, 2005 at 12:32 PM
No, I suggest one amp for the subs and a separate amp for the front and rear speakers. (if you are installing new speakers).
