Alpine Type X 12"
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64387
Printed Date: May 17, 2024 at 11:21 AM
Topic: Alpine Type X 12"
Posted By: mj239air
Subject: Alpine Type X 12"
Date Posted: October 14, 2005 at 6:05 PM
I would like to hear from those of you that have these. What kind of box do you have them in? What size of enclosure do you have? I know what the figures tell me, but I want real world experience. I have 2 of these that are going to be run off of 2 MRD-1000's. So let me know what you all have.
Posted By: youngone
Date Posted: October 14, 2005 at 6:43 PM
i dont have one but i have heard about them and seen them playing. i have one peace of advice about these subs they are really stiff when you first get them. you need to run them at half of there rms or less for well most people say 72 hours but gust to be on the safe side around 80 90 hours. you sould do this with all subs no matter what people say. better to be safe then sorry. i have seen this things gust blow strait out of the box because people dont brake them in. good luck and happy thumping. ------------- Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
Posted By: Alpine Guy
Date Posted: October 14, 2005 at 9:42 PM
They like small box's and lots of power, , and especialy like to hit the low rumble your balls kinda notes. When building a box, plot it up on WinIsd Pro from https://www.linearteam.dk/default.aspx?pageid=newdriver and it will help you build a nice box for that sub. I never really could agree on the reccomended ported box alpine has in the manual, winisd designs a way better box for you. ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: mj239air
Date Posted: October 14, 2005 at 10:24 PM
Yo AlpineGuy have you ever heard these? WinIsd said to make it 4.99 cubic feet for a sealed and 5.04 for a ported. Seems quite a bit bigger than what Alpine recommends. I know that when I plot the 12W6's that I have it tells me to also do 4.04 on a vented box and I have found that 1.75 works great. I really would like to know why it says so big of an enclosure.
Posted By: konrad100
Date Posted: October 15, 2005 at 12:46 AM
If you estimate the cars enclosure that you are sitting in (cabin), well what they do is take the avergae of most cars on the inside and create enlosure specified to that...But this is not the case, if you really want a great enclosure you have to take into consideration the cabin enclosure of your car, the pressure exerted on the walls and the thickness of the sheet metal, only then you can calculate the best box, but we all know that's not possible (or is it) it is if you are the engineer that build the car.! Alpine recommends there boxes small and watts high, well to me there watts are not enough for this sub, so about a 1/2 a cu ft bigger won't hurt, if you can create a perfectly sealed box a bit bigger then that is the way to go.
Date Posted: October 15, 2005 at 9:37 AM
humm, last time i plotted a x-12 i got a 2 cu.ft box as the optimum ported.
Posted By: ravenndude
Date Posted: October 15, 2005 at 2:54 PM
when you first plot somehting on WinISD it just gives you the flatest line. Sometimes (this being one of them) you don't want that. You have to optimize the box to get the graph you want.
Posted By: mj239air
Date Posted: October 15, 2005 at 8:23 PM
Hey guys thanks for the help. Maybe I am inputing the wrong numbers into the application. I will run it again. As for the vehicle, this is going into a suburban so for space, I am not really limited. As far as the boxes go, I will probably just build a few to see which I like the best. I was just wanting to find some starting points.
Posted By: ssnds
Date Posted: October 15, 2005 at 8:58 PM
i have been thinking about gettings these subs.. then others tell me there are other subs that blow these out of the water.. anyone have any ideas for me?
------------- SSounds
Posted By: mj239air
Date Posted: October 15, 2005 at 9:41 PM
AlpineGuy, have you heard anything good about the new DVA-9965? I am thinking about upgrading to this, but the price is kind of scary. I previously owned the 7949 and I know it was expensive as well. I just thought I would ask for your opinion on this new unit.
Date Posted: October 15, 2005 at 9:46 PM
I don't know much about anything in there head units anymore, the shop i was working at when out of business so i only hear what friends have now.
Posted By: mj239air
Date Posted: October 15, 2005 at 10:00 PM
thanks for everything already.
