I was attempting to fix a speaker that seemed to keep going out and I made stupid mistake of not disconnect the power from the battery a I accidently tapped a speaker wire to the 12 volt wire connected to my 4ch amp and now I get a very loud noise when I turn my engine on. Now I have checked all the fuses(amps & between the wires) and none of them are blown, I have tried new RCA cords, also purchased a new amp.
Help please!!
Pioneer AVIC-D1
Pioneer Ipod interface
2 pioneer 6 1/2's
2 pioneer 6x9's
1 kenwood 2ch 800watts max
1 kenwood 4ch 800watts max
1 farat capacitor
2 10' cerwin vega subs
it only happens when the car is running? does it get higher pitched or change sound when you rev up the car? try this run rca.s from a freinds head unit to your equipment. and see if the problem is still there? this will tell you if it is in your head unit or some whereafter.
it does sound like the hu. and if your handy with solder. take the radio apart on the bottom side of the main board axcessable from removing the bottom plate of the radio search the board for a burnt trace. when you find this repair it with a single strand of copper wire from a multi strand wire and solder it on that burnt trace after cleaning it with achol. so to connect that trace in the curcuit. if no burnt traces are found check the diodes in the power supply for the hu unit on the oppisite side of board if this is all forign to you go get another hu. lol
JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
I found the problem when you touch the left and right subwoofer RCA outs from the HU to ground the noise stops. So hopefully it's just the subwoofer RCA's from the HU because I can replace those but as far as soldering I've never soldered a circuit board.
