Fuse block
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67066
Printed Date: May 16, 2024 at 12:01 PM
Topic: Fuse block
Posted By: EM12986
Subject: Fuse block
Date Posted: November 26, 2005 at 4:26 PM
Ok i had a regular fuse holder.But after so long the fuse would go bad(80 amp). So i want out today and bought a anl fuse(250amps) digital fuse block. How would i hook this up so the volt and leds on it will come on. Cause if you groung it a screw or wire. It will stay lite up.I want it to go on and off with the car. The model is Raptor(PFDBM2-ANL).
Posted By: ssnds
Date Posted: November 26, 2005 at 4:33 PM
i am not really sure but. would putting a switch on that ground work?
------------- SSounds
Posted By: Alpine Guy
Date Posted: November 26, 2005 at 4:41 PM
First, make shure the led turns off when the fuse is removed so it shows when its blown. 2nd about the on off of the led you would need to get a relay and wire the 87 terminal to your (-) on the fuseblock, 86 terminal to your switched(+) power wire (ignition, accessorie), 85 and 30 go to ground.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: EM12986
Date Posted: November 26, 2005 at 4:48 PM
Yes it does turn off when the fuse is out. Thanks for the help
