MP3 straight to Amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68372
Printed Date: June 12, 2024 at 1:37 AM
Topic: MP3 straight to Amp
Posted By: dekay
Subject: MP3 straight to Amp
Date Posted: December 14, 2005 at 3:02 PM
I just have a simple question which I so far have not been able to find the answer to.
Why or how can I connect my Mp3 player straight to my Amplifier (which drives 2 6"x9" and a 12" sub)?
I do not see the need for a head, I like the idea of hiding the entire system also. Plus all my music is in Ogg Vorbis format, which my mp3 player handles correctly but all the head units I have looked at cannot.
What would be the problems with this setup, dangers, what will I loose, and/or is there a way to do this correctly.
Posted By: 7keen0
Date Posted: December 14, 2005 at 4:14 PM
You CAN do that dude but why would u want 2...u can get HU's with all kinds of animations, screen savers and all that.
But to do that take an old pair of headphones and splice it in2 a set of RCA cables and insulate it well with black tape...then plug it in2 ya amp.
But i would get a head unit
------------- "Aspire to acquire the desire that you admire but if in the process you perspire, dont retire, but refire to acquire that you disire"
Posted By: geepherder
Date Posted: December 14, 2005 at 7:59 PM
Why not use a headunit with an auxiliary input? That way you can use an headphone to RCA adapter to feed audio from your mp3 player directly into your system. ------------- My ex once told me I have a perfect face for radio.
Posted By: dekay
Date Posted: December 14, 2005 at 8:05 PM
Well the point for me is really WHY buy a head unit. My mp3 player has all the tunes I want, even a radio, and I completely care nothing for blinking lights and such. I really like the idea of an invisible setup!
My only worry was possible loss of clarity.
Date Posted: December 14, 2005 at 8:15 PM
If that's all you want, then sure, go for it. Just buy an adapter and run your RCA's to your amp.
Posted By: haemphyst
Date Posted: December 14, 2005 at 9:38 PM
You DO know such an adapter already exists, right? Don't rig it. Do it right.
Here's one...
Here's another...------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: arrow12
Date Posted: December 14, 2005 at 10:15 PM
Yea do what haemphyst said. Don't rig up a homemade pair. Spend the extra money to get a pre made one. It'll sound and look better and last longer.
------------- That's my opinion. Take it, leave it, or correct me.
Posted By: Ravendarat
Date Posted: December 14, 2005 at 11:11 PM
Ummmm, I might be reaching here but I bet the voltage output on a mp3 player is complete shhh. In fact I think most of them are so low that they are measured in millivolts not volts. Mabye a line driver could boost the voltage to a respectable level. If not then you are gonna need to use a head unit to boost the voltage to something thats actually usable
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Posted By: sedate
Date Posted: December 16, 2005 at 1:18 AM
I dunno, I was playing with my Sony Discman and I plugged it into my e6450 with one of those headphone->rca plugs you guys are talking about... I had no problem running the bejezus out of the amp with it.. I was trouble-shooting my deck though, I didn't mess around with it too much..
------------- "I'm finished!" - Daniel Plainview
Posted By: ragoal12
Date Posted: December 16, 2005 at 5:08 PM
i have heard of a few problems with the mp3 players and the volume output on them... i believe this is what Ravendarat is talking about..... the guys here ran the mp3 player through an fm modulator... but these problems arouse from playing an mp3 player thru a deck not stand alone.. ------------- S.O.B custsoms.. South Omaha, Nebraska
Posted By: JMaxx93
Date Posted: December 16, 2005 at 5:21 PM
to answer your question it won't casue any problems to you amp and that is a definate option that you have. the only issue would be to set the gains on the amp accordingly and the output voltage on the mp3 player may be low causing a lowering of the sound quality but mp3's have pretty shhhty sound quality anyway so go for it. and the adapter that you need to buy is anywhere from $2 at radioshack to $20 for a monster cable.
Posted By: 350d50
Date Posted: December 17, 2005 at 9:02 AM
That would be a pretty cool setup actually, then you could smooth the dash, run all your wiring so you have a plug hidden up front, then just plug in your player and go. Plus most mp3 players now are made with enough features to function as well as a deck. Im really digging the idea of having the smooth dash.
Posted By: satfiles
Date Posted: December 18, 2005 at 3:45 AM
Those adapters look fine if you are only pushing 2 speakers. Otherwise you have to find an adapter with 2-3 sets of outputs like any decent head unit has. If you want to push more speakers you may have some splicing to after all.
Posted By: oxygen65
Date Posted: December 18, 2005 at 3:59 AM
get a ipod interface and hook that up it will be good
Date Posted: December 18, 2005 at 11:56 AM
I dont understand what you are talking about, hook up the Ipod interface to what? ------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
