2 ohm DVC to a 2 channel amp?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71363
Printed Date: May 23, 2024 at 6:32 PM
Topic: 2 ohm DVC to a 2 channel amp?
Posted By: jscarb2
Subject: 2 ohm DVC to a 2 channel amp?
Date Posted: January 23, 2006 at 4:34 PM
can i hook up 1=dual 2ohm voice coils L7's to a 2 channel amp? it would run the amp at 2 ohms stereo right? the amp can do 2ohms stereo but i am not sure it is safe to run one coil on each channel. i have 2 12" L7's and have been running them on a mono class d sub amp at an combination series parallel for a 2 ohm load.but want to switch to 2 amps= 1 amp per1 sub. just dont want to blow my subs or fry my amps! thanks
Posted By: alpine_king
Date Posted: January 23, 2006 at 4:54 PM
why two amps??
------------- 1993 Ford Ranger.
Head Unit.Alpine CDA-9831
Front Speakers.Infinity 6010 Reference Series
Amp.Alpine MRD-M1005
Subs.3 Kicker CVR10
Rear Speakers.SPL CS-573
20" Boss 312's, lowered 3/4
Posted By: jscarb2
Date Posted: January 23, 2006 at 4:59 PM
just want more power than my mono amp has:)
Date Posted: January 23, 2006 at 5:03 PM
did you already buy the second amp?
Subs.3 Kicker CVR10
Posted By: jscarb2
Date Posted: January 23, 2006 at 5:05 PM
i all ready have 2 matching amps from another sytem i had.
Date Posted: January 23, 2006 at 5:11 PM
well i cant tell you much because ive never hooked up a voice coil to each channel, but it can be done. as long as the amp can run 2 ohms stable on each channel, you should have no problem.
Subs.3 Kicker CVR10
Posted By: forbidden
Date Posted: January 23, 2006 at 5:53 PM
Wire the sub in series to make it a single 4 ohm load, connect it to the bridged outputs of the 2 channel amp.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: jscarb2
Date Posted: January 23, 2006 at 5:57 PM
so i cant hook a coil to each channel? the reason is it makes more power at 2 ohms stereo than at 4 ohms bridged! and the amp will not do 2 ohms bridged it will but they overheat where i have to mount them if they are bridged 2ohms, but stereo 2 ohms they run cool
Date Posted: January 23, 2006 at 6:05 PM
No the amp will not make more power at 2 ohm stereo as compared to 4 ohm bridged. 2 ohm stereo and 4 ohm bridged are for the most part the exact same thing. The amp will not do 2 ohm bridged as that is also 1 ohm stereo (which it will not do either). Here is how to wire the sub. Option 2 (series) = 4 ohm load Voice coils wired in series Recommended Amplifier: Stable at 4, 2, or 1 ohm mono |
Posted By: jscarb2
Date Posted: January 23, 2006 at 6:08 PM
ok but my qustion was can i hok up a voice coil to each channel of the amp safely?
Date Posted: January 23, 2006 at 6:12 PM
Yes and no. Yes it can be done provided you also take into account any degree of difference between the channels, the crossovers, the input voltage etc. This is why it is best to run the amp in bridged mode. In bridged mode, all of the concerns are all taken care of to enable you to play the driver safely. Myself, I would not wire a dual 2 ohm sub in stereo to a 2 channel amp.
