Amp and sub, 06 Xb
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72425
Printed Date: May 31, 2024 at 11:34 PM
Topic: Amp and sub, 06 Xb
Posted By: jesussalvdr
Subject: Amp and sub, 06 Xb
Date Posted: February 08, 2006 at 11:10 AM
Hi, I have a ALPINE MRV-1000 2/1 channel amp. and a POWER ACOUSTIK FUBR-12. I have generally only done car security systems and general speaker installations. I was wondering what would be the basic components i would need to install, any amp kit will do? also how will I wire the thing up?
I know i'll have a heavy gauge hooked up from the batt with fuse. then rca wires from the head unit. (06 Xb base, does it have rca audio out option? ) and then a control wire from the hu to the amp, for powering on.
------------- hey dude
Posted By: geepherder
Date Posted: February 08, 2006 at 8:48 PM
You'll need to tap into the speaker wires, and connect a line output converter. Then you can run RCA's from that to your amp. Tap either fronts or rears- if you have a factory sub (I don't think you do) you'll tap into those wires.
------------- My ex once told me I have a perfect face for radio.
Date Posted: February 09, 2006 at 12:38 AM
The stock HU doesn't have any rca outputs on the 06 model?
Posted By: outtaluck72
Date Posted: February 09, 2006 at 8:11 AM
no rca's on the factory radio. BTW, why don't you look into a new radio? I find it funny that the majority of Scion owners (I own a 2005 xB) will put a full system in and not switch out the factory radio. that was the first thing I did.
Date Posted: February 09, 2006 at 10:26 PM
I know that, Jessie, that's why you'd use the line out converter- it uses speaker level signals and converts them into rca outputs. ------------- My ex once told me I have a perfect face for radio.
