wiring bose amp in another car
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72429
Printed Date: May 16, 2024 at 5:33 AM
Topic: wiring bose amp in another car
Posted By: imokureok4
Subject: wiring bose amp in another car
Date Posted: February 08, 2006 at 12:23 PM
I recently took a bose stereo system except for the deck out of a 2004 chevy suburban it includes the bose amp that was under the console 2 tweeters, 2 front speakers, and 4 rear speakers now what i want to do is wire all this into my dads van that has an aftermarket kenwood deck. i know that i need to match the colors of each speaker to the amp and i need to find out what is power,acc,and ground but what other wires will i need to hook up, is this possible??
Posted By: sk8ingsmurf
Date Posted: February 08, 2006 at 1:00 PM
possible but not easy in any sense of the word, and really pretty pointless. Those bose systems really arent exactly great, may not be terrible for a factory setup, but just overall wouldnt be worth your time to do.
Posted By: gus1
Date Posted: February 08, 2006 at 3:45 PM
I wouldn't bother......
1) Many Bose systems are vehicle specific as far as EQ, placement, etc.
2) making it work with the Kenwood deck will be a PITA, especially if the OEM deck that was on the BOSE system was Class2
3) It's BOSE.... why????
4) Did you get the factory sub?
5) An aftermarket solution will be far more reliable in the long run.
6) It's still a BOSE system.....
In the long run.... the BOSE crap was far happier in the Suburban. It should stay there.
Gus
------------- Wherever I go, that is where I end up......
Posted By: coppellstereo
Date Posted: February 08, 2006 at 5:11 PM
The bose amp really isnt meant to work with any other speakers, they are typically low power and work with weird impendances
Posted By: integratyper934
Date Posted: April 27, 2006 at 12:58 AM
whats the point of that????? there isnt even gain adjustments or rca's just a huge waste of time...........
Posted By: cntrylvr79
Date Posted: April 27, 2006 at 10:50 AM
Not to mention the bose amp uses the class II datbus to turn on and the signal from deck to amp is non standard as well.
------------- Cause I'm So white and nerdy...
First Class Certi-fried installer
