A proper cut-cab?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72746
Printed Date: June 04, 2024 at 1:16 AM
Topic: A proper cut-cab?
Posted By: nu age
Subject: A proper cut-cab?
Date Posted: February 13, 2006 at 10:46 AM
I'm going to do a cut-cab in my canyon and wanted a little input. Does the box always have to be Line-Xed or will fiberglass be okay? I did a search and read that I need to put supports in the box and to minus it from the air space but what makes it different from a box in a trunk, they never have any support? I would like to build my box out of MDF and then fiberglass the whole box so I can piant it to match my truck. Does the box need to be a certain distance from the cab and the rear seat? Any pros and cons would be helpful. Thanks in advance, Fred.
Posted By: rottenbelly
Date Posted: February 13, 2006 at 4:16 PM
I have done a couple and am about to do another. I have fiberglassed one and is still in great shape after many rainstorms. I would line x or spray rubber undercoating on bottom then paint over fiberglass to match the top. I have mine back 13 inches so i could put amp and stuff on bottom of bed.My friends is right up against the bed and sounds great also. i would recommend a tonneau cover,checkerpro has great prices. As for supports just brace box well. flexing box equals trouble,just add the volume the brace takes up back into box.
------------- rottenbellys 05 crew cab colorado.Pioneer dehp 880prs, kenwood excelon in all 4 doors. Bazooka 500 mono Jl 10w3 in coustom center console box.
Posted By: nu age
Date Posted: February 13, 2006 at 8:32 PM
Thanks rottenbelly. Any more opinions?
Posted By: nu age
Date Posted: February 14, 2006 at 5:19 PM
