2000 Gmc Jimmy Stereo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73948
Printed Date: April 28, 2024 at 3:46 PM
Topic: 2000 Gmc Jimmy Stereo
Posted By: runyanzoo
Subject: 2000 Gmc Jimmy Stereo
Date Posted: March 04, 2006 at 11:24 PM
I am needing any information on the bose sound system in the 2000 gmc jimmy bose sound system and its wiring. I want to take the head unit out and replace it and leave everything else, but I do not know what wires go where in the truck. I am needing the know where the wires go to from thr plugs in the amp and the stereo.
Posted By: ss-installer
Date Posted: March 04, 2006 at 11:50 PM
dont cut the harness. just buy an adapter and color code the wires. saves a huge headache.
Posted By: sparkie
Date Posted: March 05, 2006 at 10:52 AM
You need to find a proper adaptor for your system. The BOSE system requires a low level signal from the radio into the amp. If you hook up the high level output/speaker output from an aftermarket deck, you will overload the BOSE amp. Bypassing the amp may not be possible either. Some BOSE speakers aren't the correct impedance for aftermarket decks. They can be anywhere from 1/2 ohm to 4 ohm. Hooking the wrong type to your new deck will damage it. See if anyone has a interface to step the signal level down to a level the BOSE amp can handle.
------------- sparky
Date Posted: March 05, 2006 at 8:01 PM
thank you for the help it answers a lot i have found an adaptor to go between the factory amp and the aftermarket stereo but it is like $80 dollars. So bypassing the amp may not work either. well any suggestions I figurer the speaker would not be that different and would not matter, the only thing is that the front door speakers are loike subs abd there is tweeters in the dash. Any info one what to do from here is helpful too thank you.....
Posted By: xscash
Date Posted: March 05, 2006 at 8:18 PM
buy the bose add-a-head. trust me running new wiring will take longer than working overtime and paying the 80$
Posted By: kirktcashalini
Date Posted: March 06, 2006 at 1:49 PM
damn, i am glad that my blazer doesnt have the bose, but glad it has every other option ------------- 99 Blazer LT. Yellow Top. Big 3. Infinity Kappa Speakers All Around. Jensen CD/DVD flip out. 2 Infinity Kappa Perfect 12DVQs powered by a Alpine PDX600.1 (in one custom box, building a FG box)
Date Posted: March 06, 2006 at 3:40 PM
If I change out the speakers in the dash and the doors and bypass the amp then will it work or will i have to remove all the wiring as well.
Posted By: forbidden
Date Posted: March 06, 2006 at 6:23 PM
You will need to run new wiring as well.
------------- Top Secret, I can tell you but then my wife will kill me.
Date Posted: March 06, 2006 at 8:17 PM
Okay then I guess if i want to do what i really want to then i will have to get the adaptors to make it all work, because what i really want to do is put a dvd player in it and extre monitors in to also. so i guess the pac oem-1 or oem-2 is my best way to go tghen to change out the head unit.
