amps shut off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75595
Printed Date: May 17, 2024 at 9:14 PM
Topic: amps shut off
Posted By: the_one369
Subject: amps shut off
Date Posted: April 03, 2006 at 1:44 AM
i am running 2 kenwood Kac-7201's amps...my question is that they have been working fine and just yesterday both of the amps shut off at the same time then they came back on then i smelt like something was burnt whats goin on?
Posted By: Aruman
Date Posted: April 03, 2006 at 7:58 AM
re-check your wires if nothing is loose.
------------- Shaking The Neighborhood
Date Posted: April 04, 2006 at 2:08 AM
all of my wires are tightly in place any other ideas?
Posted By: ss-installer
Date Posted: April 04, 2006 at 6:45 AM
check ohm loads?
Date Posted: April 05, 2006 at 2:03 PM
each amp is bridged to 4 ohms so theres no problem there with the ohm load
Date Posted: April 05, 2006 at 9:01 PM
ok so i found out the problem.....i melted my main fuse it didn't blow for some reason???? i am running an 80A blade fuse so my new question is do i need to run a bigger fuse or something different??? i am running 2 800watt amps
Posted By: j_darling2007
Date Posted: April 05, 2006 at 9:26 PM
What size of wire are you running? What size fuses does each amplifier have? ------------- There are 3 kinds of people in the world, those who can count and those who can't
Posted By: austincustoms
Date Posted: April 06, 2006 at 12:55 AM
Don't let the smoke out of your equipment, you can't put it back in.
Date Posted: April 06, 2006 at 2:58 AM
heres my setup hope it doesn't confuse you guys battery----4 gauge----80A fuse---4 gauge--------cap-----split into two 8 gauge-----amps
Date Posted: April 06, 2006 at 1:19 PM
You would be safe to fuse the 4 gauge wire at 150, however, you need to fuse it at the total current draw on the wire (both amplifiers). For example, if each amp is fused at 40 amps, you would need an 80 amp inline fuse; if both are fused at 50, you would need a 100. What is each amp fused at. If the correct fuse blows, it means you have a short somewhere. ------------- There are 3 kinds of people in the world, those who can count and those who can't
Date Posted: April 06, 2006 at 3:45 PM
each amp is fused at 30 i just went out and bought an ANL 150 fuse do you think that it would fix the problem
Posted By: geepherder
Date Posted: April 06, 2006 at 8:39 PM
Explain what you mean by "melted the fuse"- is the metal conductor broken or did the plastic melt? If the plastic melted, then it's too close to a heat source- relocate it elsewhere. If the conductor is broken, and you're unable to locate a short anywhere, I'd try the new fuse. I've seen the glass type come unfused at the ends under normal use, but not a blade type. Let us know how it turns out. ------------- My ex once told me I have a perfect face for radio.
Date Posted: April 07, 2006 at 9:37 PM
You need a 60 amp main fuse. If the actual metal is melting, it means you have a short. But, like geepherder mentioned, if the actual plastic melted, it is too close to heat. It is possible the wire is grounding out or maybe an amplifier is fried. Let us know how it goes. Jacob ------------- There are 3 kinds of people in the world, those who can count and those who can't
