subs work but not from back/door speakers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76997
Printed Date: October 31, 2024 at 6:54 PM
Topic: subs work but not from back/door speakers
Posted By: aliendisaster
Subject: subs work but not from back/door speakers
Date Posted: April 28, 2006 at 9:20 PM
My amp and head unit just got jacked so i got new ones. The head unit is a new clarion and is hooked up correctly. All lights come on, cd's play, and subs work but I can not get any sound out of the back and door speakers. I took one of the speakers out of the door and went straight from the head unit to the speaker but nothing. I read a post saying one of the speakers could be grounded but I haven't had a chance to check this. Is there anything else that could cause this? All fuses are good. Car is a 92 civic ex.
Posted By: jayson358
Date Posted: April 28, 2006 at 9:59 PM
some head units have an option to be able to turn off the built in amp i know jvc arsonal line can that might be it so check the owners manual to sse if it has that option
93 diamante
pioneer deh-p3800mp
crossfire 40 band eq
alphasonik pma4075 mid amp
clif designs cd10.1Lx sub amp
powerbass xtreme 6 1/2 comp
"   " 6x9 rear
alpine 2 12" type r
ported 40hz tune
Posted By: stevdart
Date Posted: April 29, 2006 at 5:52 AM
You need to post model numbers, and direct links are even better, to the head unit, sub amp and any other amps or equipment hooked up.
Date Posted: April 29, 2006 at 4:47 PM
Ok. I have figured out that it is one of the speaker wires. It's the passenger side door speaker. When I unhook it, everything plays fine. Now I have to figure out how to fix that. I took my dash apart but cant see the wire touching metal. The wire is inside the sleeve most of the length. Does anyone know how I can find the ground?
