Why no bass?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80383
Printed Date: June 06, 2024 at 8:14 PM
Topic: Why no bass?
Posted By: arkansasboy
Subject: Why no bass?
Date Posted: July 17, 2006 at 1:45 AM
Ok my friend has a lancer and he has two Memphis 10's and a cheapo 750 amp and it is hooked up to his factory cd player. Ok I know having a factory cd player isnt great but man you can hardly hear and bass at all. What the probablem?
------------- Dan Tha Man
Posted By: forbidden
Date Posted: July 17, 2006 at 2:02 AM
Disconnect one sub and see if it magically has bass. If it does, one sub was wired backwards, called out of phase. And yes, I never sleep.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: MrSuperStar
Date Posted: July 17, 2006 at 12:09 PM
you must also check the connections and levels of the line out converter that may have been used. A mistake there would have the same effect of a sub wired backwards.
Posted By: aznboi3644
Date Posted: July 17, 2006 at 5:18 PM
Could check if your friend even has the amp hooked up to the battery with a power wire and if it is even grounded...remote wire?? amp connected to sub with speaker wire?? are the subs even in a box??
Just some simple suggestions for what to check.
And who needs sleep??? I'll sleep when I'm dead.
