db meter placement
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80448
Printed Date: May 07, 2024 at 11:00 PM
Topic: db meter placement
Posted By: jeffchilcott
Subject: db meter placement
Date Posted: July 18, 2006 at 5:41 PM
All db drag comps are done on the windshield, that is the way they keep every car equal.
USACi You can place the meter anywhere in front of the B pillar, best results are normally on the floor board passenger side with the drivers side window or door open. That helps build pressure on the passnger side where the meter is
On the windsheild is a harder place to et higher #'s but a little more consistant from car to car
In front of the port or vent would be a port wars score...Yes it will produce a very high # but no where near a resiemblance of what the car really does.
If you really wan to know what your car does in a daily application, go to a USACi show and run in street Beat. 30 second average of all sub frequencys using music only, no tones.......average scores this weekend were 125-130db in these classes.
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: July 18, 2006 at 6:13 PM
I would go passenger side floor board, with the drivers side window open, it help the pressure direct diffrently. I have seen anywhere from 2-5 db in tone/outlaw runs and 2-3db in street beat runs
where are you from? I might be judging a show in your area sometime and would be ahppy to help you out
2007 World Record
Date Posted: July 18, 2006 at 6:34 PM
7/29/2006 6:00:00 PM 1 EXTREME SOUND LAB RIPLEY MS 662-837-2345 SPL SP
7/30/2006 10:00:00 AM 1 EXTEREM SOUND LAB RIPLEY MS 662-837-2345 FE+CS DP
8/4/2006 5:00:00 PM 1 AUDIOWAVE GAUTIER MS 228-497-0022 SPL+CS SP
8/5/2006 12:00:00 PM 1 COWBOY MALONEY'S HATTIESBURG MS 601-264-8955 FE+CS SP
8/6/2006 11:00:00 AM 1 EMPRESS AUDIO PEARL MS 601-939-7730 FE+CS SP
8/26/2006 12:00:00 PM 1 MIRO'S MUSIC SHOPPE CLARKSDALE MS 662-627-2640 SPL+CS SP
9/9/2006 12:00:00 PM 1 COWBOY MALONEY'S JACKSON MS 601-956-5323 FE+CS DP
9/16/2006 10:00:00 AM 1 EXTREME SOUND LAB RIPLEY MS 662-837-2345 FE TP
10/21/2006 5:00:00 PM 1 TUNER JAM JACKSON MS 479-750-0505 FE+CS TP
there are some shows in your state, unsure if I will be judging any of them, or how far they are for you.
I typically stay in MO,KS,KY,IL,NE,IA the midwest. But that dosent mean I wont get put on one of those shows I will let you know if I do
This weekend I think I will be in Memphis,TN
2007 World Record
Date Posted: July 18, 2006 at 8:10 PM
I will let you know if the show is going to happen. But it is suppoosed to be at a mortorsports autoplex in Memphis,TN
yes this coming weekend, friday night...the show is supposed to start at 6:00pm I will post more tomorrow when I get a call from USACi, telling me if im going
2007 World Record
