jl audio 12w6v2 wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81224
Printed Date: March 21, 2026 at 6:58 PM
Topic: jl audio 12w6v2 wiring
Posted By: reefguy
Subject: jl audio 12w6v2 wiring
Date Posted: August 05, 2006 at 3:11 AM
has anyone wired 2 jl 12w6v2 dvc 4ohm subs. i having a bit of confusion on the jumpers, anyone advice would be great.
Posted By: stevdart
Date Posted: August 05, 2006 at 5:21 AM
https://mobile.jlaudio.com/pdfs/7876.pdf What's your intended impedance load with two of these subs, 4 ohms or 1 ohm? Use https://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42 as your guide. For the 4 ohm impedance, jumper wires are used for a series connection, then the subs are paralleled together. ------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: reefguy
Date Posted: August 05, 2006 at 1:04 PM
well, i want both 2 dvc 4ohm subs wired so i get a 4 ohm impendence so my ppi a1200.2 amp runs in 4 ohm which will yield the bridged mono wattage amount, but i cannot seem to get the jumper wires correctly to get 4 ohms impedence output. thanks for the manual i have it already, but both pics have jumper connected for 2 or 8ohms. i need final 4ohms after they are wired in series or parallel.
Posted By: reefguy
Date Posted: August 05, 2006 at 1:14 PM
too bad the jl manual only has jumper pics for 8 ohm and 2 ohm, how about 4 ohm?
Posted By: reefguy
Date Posted: August 05, 2006 at 2:09 PM
if using the second option #2 config. to get a final 4 ohm, but lets take that option 2 pic and apply it to the jl sub jumpers, start at the right end sub. label it the (neg.) vc1- to vc2+(pos) , so what happens to vc1+ to vc2-? so how do i appy the option 2 pic setup, to match the jumpers on the jl sub. am i missing something?
Posted By: dangerranger96
Date Posted: August 05, 2006 at 6:19 PM
Wire the jumpers as in diagram A in the manual, then negative from first sub, to negative on the second sub to negative on the amp, and positive from first sub to positive on second sub to positive on amp.
------------- 97 F150, Sony CDX-M630, Sony XM-2165GTX, JL Audio 12W3D2, Planet Audio VX-602, Memphis 15-MC5.7
Yeah it's a mutt, but mutts make the best dogs!
Posted By: stevdart
Date Posted: August 05, 2006 at 11:06 PM
You seem to be missing the fact that you have TWO of these subwoofers (unless I read your post wrong...). Each sub has voice coils wired in series to 8 ohms. So you have two 8 ohm subs. The two subs are parallel-wired to each other to make a total 4 ohm load. ------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: killer sonata
Date Posted: August 05, 2006 at 11:12 PM
seems logical to me. Dont forgtet about the woofer configuration tool on this site. ------------- "People with mullets live 40% longer" - Ricky Bobby
Posted By: reefguy
Date Posted: August 06, 2006 at 1:59 PM
so what you guys are says that using diagram A, even though only one jumper wire is used, the wattage still flow thru both coils? these subs are dual 4 ohms, each coil is 4 ohms, they are wired like in diagram b (vc1- to vc2-) then ( vc1+ to vc2+) in the manual its final nominal impendence is 2 ohms(factory wired).
Date Posted: August 06, 2006 at 2:07 PM
yes ------------- 97 F150, Sony CDX-M630, Sony XM-2165GTX, JL Audio 12W3D2, Planet Audio VX-602, Memphis 15-MC5.7
