SPL setup Fosgte vs Kicker
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82676
Printed Date: May 01, 2024 at 7:03 AM
Topic: SPL setup Fosgte vs Kicker
Posted By: hapache
Subject: SPL setup Fosgte vs Kicker
Date Posted: September 09, 2006 at 9:10 PM
This is the deal I'm looking to compete this year with my 2002 Camry This is my equipement My opponent 2) Kicker L7 12's (2005's), 4cu Box /Poly-filled, 2) 15 T2's , wired to 1ohm (im sure), Wired to 1ohm, Round Ports 4'' / 7'' long 5cu BOX (Not Sure) 1) 1800 kinetik battery 2) Red tops pioneer HU 7600mp Old clarion Flip-out Model#? stock alternator (strapped for cash) 160amp Alt. 0 gauge everything / (No fuses) when competing O gauge everything / fused Monster cable RCA's Pro's Cheap RCA's 1)Earthquake Phd2 Amp (Modified) 1)Rockford fosgate T20001bd fuse was changed to 40 Capable of hitting 150.1 db's Last SPL Comp 148.7db (door open) (outlaw class) ------------- I'm on a mission to be as loud as i wanna be.
Posted By: hapache
Date Posted: September 09, 2006 at 9:51 PM
Do you guys think i have a chance to beat him? Any suggestions? ------------- I'm on a mission to be as loud as i wanna be.
Posted By: hapache
Date Posted: September 09, 2006 at 9:54 PM
By the way he has the same car 2002 camry.!
Posted By: killer sonata
Date Posted: September 09, 2006 at 10:55 PM
why in the world wouldnt you run fuses while competing? doesnt do you much good if your car starts on fire.
Posted By: fosgate152ohm
Date Posted: September 10, 2006 at 12:58 AM
unless your running gobs of power and dont care about the well being of your cars safety then hell go without a fuse but belive me when things go wrong they go WRONG no using fuses
Date Posted: September 10, 2006 at 1:00 AM
iv got a phd2 in just about brand new shape im seling for 300 plus shipping which wouldnt be that much because its no that large. those things are beasty
Posted By: conseit68
Date Posted: September 10, 2006 at 8:28 AM
i hope you have insurance with running no fuses. and good luck on beating him.
Posted By: jeffchilcott
Date Posted: September 10, 2006 at 12:47 PM
First off what do you mean by the fact your amp was "midified"
second pulling fuses out is only worth .2-.3 db in a very vry high current setup 200+ amps of actual draw
You meantioned nothing about the tuning frequency your box is at....I know you gave box size and port length but Im being lazy. I would reccomend tuning yor box to 42-47hz and try running a sweeep (track 19 on all sanctioned cd's) and see where your loudest score was (what frequency) and use that
charging system is everything! You cannot make power without providing the amps with power. I would highly look into upgrading the big 3 if you havnt yet, and get that high output alt that you need!
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: hapache
Date Posted: September 10, 2006 at 2:22 PM
Ok i Get it I must use a fuse! what amp size fuse. jeffchilcott its about 45hz, / changing out to a bigger internal fuse is what i call modified / so its not true that you can make it with a stock alt. and a powerful battery / other things that were suggested to me was : Use the front or rear signal outputs of the Headunit to your amp because the signal is cleaner Open up your amp to 200hz , so the amp will play with more power, less resistance and catch the best frequency. ------------- I'm on a mission to be as loud as i wanna be.
Date Posted: September 10, 2006 at 2:32 PM
I normally open my amps to 200hz but havent done alot of testing otherwise....made a few whoops moments and had it set at 50 hz on accident and it brought our scores down a few tenths
The output of the head unit shouldnt make any diffrence
You can use the stock alt to drive to the show.. Like I do..But I have 4 batteries in one car, and 6 in the other...we use very large high amp chargers o get our batteries to a full charge before going into the lane..
Find a good "Mic Monkey" somone who can hold the mic on the passenger side floorboard and get themselves scrunched up aginst the dash to build a "pocket" where the mic is on the floorboard. Leave your drivers door all the way open during the run
2007 World Record
Posted By: hapache
Date Posted: September 10, 2006 at 3:52 PM
Jeffchilcott----When I said the front and the rear of the HU , I meant versus the Signal of the sub output. Do you think I will need another kinetik battery? and what size? Where can I test my SPLs before comp? ------------- I'm on a mission to be as loud as i wanna be.
Date Posted: September 10, 2006 at 4:51 PM
The diffrence between outputs will be none.....some decks have a stonger output on the sub output (voltage) so I would stick to the sub output on your deck
I am not entirely happy with kinetiks customer support right now so I have started using a new product
They are called audioforce batteries...you can find them at batteriesareus.com Just as strong as any kinetik or powermaster battery but a better price and better customer support!
To test you setup before a show I would call some local shops that have held shows and ask if they have a term-lab or metering setup, most will gladly help you out or rent it to you at the shop for $20 a hour
Where are you located? I could probably rfer you to some shops or competitors in your area
2007 World Record
Posted By: hapache
Date Posted: September 10, 2006 at 10:49 PM
I must first say thank you for your assistance. These batteries you stated , you would really put them up against kenitik batteries! / I really want to try and beat this guy , he too c**ky. I Live in deerfield beach FL, 33067 One more thing Dynamat, where should i lay it down , or do i need it at all ,because the trunk of the 02' camry is kind of funny, when i drop the back seats, there is an oval shape that leads into the trunk. ------------- I'm on a mission to be as loud as i wanna be.
Date Posted: September 11, 2006 at 7:51 AM
The Batteries are actually made by the same manfacturer as that makes kinetik and odyesee batteries. The prices and customer service beat kinetik hands down
I havent really played alot with sound deadning...I know we did the whole trunk in meghans car, and I really didnt notice any substantial gain or loss
2007 World Record
Date Posted: September 11, 2006 at 10:07 AM
If you have been going about this for years, why is it I havent heard of you or seen you at any of the shows we have had just a few hours from you? Got any stats DJ?
2007 World Record
Posted By: haemphyst
Date Posted: September 11, 2006 at 3:47 PM
djscustomz wrote:
You seriously dont have dynamat.... and you think you are going to win... first of all you havepotential but you are going at it all wrong....i have been doing this for years and even I know that dynamat makes a huge difference in the competition level... I have closed cell foam in the dead space and 2 layers of dynamat extreme on the COMPLETE inside of my spl vehicle....pm me for the advice you need....
Can you say "Smackdown?"
Some people should read what they're posting to or against before sticking their foot in their e-mouth! ------------- It all reminds me of something that Moličre once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: hapache
Date Posted: September 11, 2006 at 7:00 PM
Jeffchilcott thanx for the insight I will into that. Any other words of wisdom, Because I'm looking at isaca Daytona 07' also. ------------- I'm on a mission to be as loud as i wanna be.
Date Posted: September 11, 2006 at 10:04 PM
I am not a big ISACA fan...I have always been a USACi competitor and have been involved with a few DB Drag shows, but havent ran at any myslef. The biggest thing I can say is find the fourm for which ever orgnazation you decide to compete in and look around.
USACi-Soundoff.org...left hand colum says fourm
DbDrag.com same left hand side says audio fourm
I will say best of luck, and hang on! This thing we call competition is very very addictive
2007 World Record
