Line Converter on GM Bose
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83342
Printed Date: May 21, 2026 at 12:20 PM
Topic: Line Converter on GM Bose
Posted By: deadpresidents
Subject: Line Converter on GM Bose
Date Posted: September 25, 2006 at 8:42 PM
Ok, I am skipping on buying the pac gm24 or whatever it is becuase I know this is not much more than a high qaulity line converter and it is somewhat out of reach becuase I need to get this stuff installed tom night.  I want an unlfiltered out put from the factory radio before it hits the factory amp. Does anybody know which 4 wires to use? which colors are they? ect. I know I can figure this out, but I would honestly rather go about it this way instead of jacking aroudn with it later. Thanks, Derrick
Posted By: Velocity Motors
Date Posted: September 26, 2006 at 1:11 PM
Derrick, depending on the vehicle, the amplifier for the Bose system is at the speaker itself. You will need to rewire the speakers and remove the amplifier output to them.
Date Posted: September 26, 2006 at 4:10 PM
I know what you are saying, but I am just trying to pull a signal to run to an amp for subs. I will be using a line level converter.
