Speaker Ground
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84067
Printed Date: January 28, 2026 at 7:22 PM
Topic: Speaker Ground
Posted By: jettagli03
Subject: Speaker Ground
Date Posted: October 12, 2006 at 10:05 PM
So I was putting in some new wires in my car today. I have a trunk mounted amp for my speakers and when I put the negative speaker lead in the terminal it played fine. Me just being curious took the negative lead of the wire out and touched it to bare metal instead and the speaker played noticably louder.
I guess my question is it better to seperately ground the speaker or to just run it back to the amp? Should it effect the speaker that much as it was doing mine?
Posted By: stevdart
Date Posted: October 12, 2006 at 10:17 PM
Check your wiring at the amp terminals for loose strands touching where they don't belong....to begin with.
Speakers operate with AC.  A signal goes to the speaker through both + and -.  The chassis should not provide this signal, therefore some wiring is not where it should be.
Posted By: wvsquirrel
Date Posted: October 13, 2006 at 1:01 AM
Stupid question, but is the negative lead of your amp grounded to bare metal? Or is ti just grounded to a bolt?
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Date Posted: October 23, 2006 at 1:42 PM
I have double and triple checked every single connection in my car since I had this little "incident"
It's grounded to bare metal but I never did check it with a DMM to see how good it was.. which I'm thinking about doing one of these days when I have time.
I was and still am totally confused.
