mono block amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84084
Printed Date: January 28, 2026 at 10:55 AM
Topic: mono block amp
Posted By: lamigra05
Subject: mono block amp
Date Posted: October 13, 2006 at 11:01 AM
sorry if this is retorical, but is the monoblock class D amplifier only for one subwoofer? or can u get more subs hooked up to it. and if so how is that?
------------- wat it do?
Posted By: wvsquirrel
Date Posted: October 13, 2006 at 11:49 AM
A mono-block class-D amp can be used for multiple subs.
It's important to get the impedence right though and match the amp to the subs (or vice-versa). This is a must for proper function.
here's an example...
 ------------- Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Date Posted: October 13, 2006 at 11:50 AM
im so stupid. ok what i mean to say is, i got a mtx 12 inch 9500 series and im about to get me an MTX 81001 about 1500 watts u think its safe to get another sub and hook it up like that?
Date Posted: October 13, 2006 at 11:51 AM
Are you looking to buy a system? if so what are you looking for...amps, subs, etc (make and model) ------------- Squirrel
Date Posted: October 13, 2006 at 11:52 AM
give me a minute to look up the specs ------------- Squirrel
Date Posted: October 13, 2006 at 11:55 AM
Are you using the SVC or DVC model MTX sub? ------------- Squirrel
Date Posted: October 13, 2006 at 11:56 AM
im just deciding if i should get another sub for my car. thats all. what do u think?
Date Posted: October 13, 2006 at 12:01 PM
sorry man i dont know what i got. what do they mean?
Date Posted: October 13, 2006 at 12:02 PM
Here's your specs if you have the DVC sub...
MTX T-9512
4ohm DVC rated 500RMS 1000Peak
MTX 81001
class-d mono-block amp
1ohm stable
500x1@4ohms
1000x1@2ohms
1500x1@1ohm
If you buy another T-9512 4ohm DVC then you can wire them together for a 1ohm total load. Each sub would receive apx 750watts (although I think the amp has overrated specs). Make sure you set the gains correctly and you should be ok.
Date Posted: October 13, 2006 at 12:05 PM
You have to look on the back of the sub where the terminals are. A Single Voice Coil sub will have 1 set of terminals. A Dual Voice Coil sub will have 2 sets of terminals to hook the wires too.
Do you have the box or manual that came with the sub?
Date Posted: October 13, 2006 at 12:06 PM
If you have the SVC model sub, then you can wire (2) together for a 2ohm load and each sub would receive apx 500 watts. Here's how that would look...
Date Posted: October 13, 2006 at 12:09 PM
well i apreciate this very much man.
Date Posted: October 13, 2006 at 12:15 PM
No problem, glad to help. ------------- Squirrel
