Upgrading to a Monsoon headunit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85487
Printed Date: May 28, 2024 at 2:12 PM
Topic: Upgrading to a Monsoon headunit
Posted By: grandprix92
Subject: Upgrading to a Monsoon headunit
Date Posted: November 11, 2006 at 5:33 PM
Hello all. I have a 1992 Pontiac Grand Prix. I recently purchased a newer GM headunit, a Monsoon MP3 player from a 2004 Grand Am.
Is it possible to make this headunit work in my car?
I spliced the factory wiring harness on the new Monsoon into my cars wiring, however, I cant seem to get it functional.
I was able to get the clock to show, and the drive makes noise when I press the CD eject button. Also, I believe the theftlock is de-activated due to the light not blinking.
On the back of the new radio, there is room for (2) connections. One, a 24pin, and the other a 12pin. Does the 12v need to be wired somewhere for my application?
Any help or insight would be helpful, Thanks.
Posted By: DYohn
Date Posted: November 11, 2006 at 6:43 PM
I believe all the Monsoon systems use external amplifiers. You'd be MUCH better off to dump that thing and purchase ANY good quality after-market head unit. ------------- Support the12volt.com
Posted By: cntrylvr79
Date Posted: November 12, 2006 at 12:29 AM
Yup, not to mention the radio from the grand am uses a data line for turn on not a standard +12 volt trigger like what the car outputs.
------------- Cause I'm So white and nerdy...
First Class Certi-fried installer
Posted By: wrenches
Date Posted: November 12, 2006 at 9:30 AM
Not to mention that the 2004 radio will be double din and you '92 is only din and a half.
Date Posted: November 12, 2006 at 10:36 AM
Thanks for the quick replys.
DYohn- I like to retain a stock look, and aftermarket isnt an option to me.
wrenches- Yes the 1992 is 1.5 din, yet I did fit this radio into proper location with rather very little modding. (The new one woulda mounted different)
cntrylvr79-Hmm interesting, do you know how many volts is applied to it, is there a solution to this?
Posted By: sparkie
Date Posted: November 12, 2006 at 2:54 PM
You will never get that radio to work in your car. It is a Class II data radio. To make it work, it must receive a message from the BCM from the car you took it from. It checks the serial number of the car and then allows it to work. Unless you decide to change the entire electrical system and motor from one car to another you are trying the impossible. Stop wasting your time and get another radio. Next time check to see if it will be compatible with your car, before you chop it up. Any GM radio that is a double din size is a Class II unit. The Monsoon label on the radio means nothing. It is no different than the same radio without the Monsoon writing on the front. The difference is that the Monsoon systems have an outboard amp and different speakers.
------------- sparky
Posted By: 90s civ and sub
Date Posted: January 07, 2007 at 9:40 AM
For the love of God, save yourself the pain & sacrificed sound quality. Go aftermarket. After working to bypass the "Monsuck" system in an 03 Jetta, I can safely say that Monsoon is the work of the Devil.
------------- 90 Civic DX Hatchback- 135 amp alternator
92 Suburban - 200 amp alternator
Stereo rebirth, coming soon. . . .
Posted By: 410440
Date Posted: January 12, 2007 at 10:05 AM
Stupidest thing i have ever read.... why for the love of car audio.... WHY? just go get an aftermarket, it is better. period. ------------- Matthew Robertson
Senior Installer
Best Buy Deerfoot Meadows
Calgary, AB, Canada
