Illumination and dimmer explained?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86927
Printed Date: June 08, 2024 at 9:01 AM
Topic: Illumination and dimmer explained?
Posted By: tillithz
Subject: Illumination and dimmer explained?
Date Posted: December 09, 2006 at 3:47 PM
Would someone be so kind as to explain what the Illumination/dimmer is in a newer vehicle? Newer being 2000 and up. Also, would it be possible to get an explanation of polarity (if D.C.) or pulsed (if A.C.)
I know many times we dont use this particular wire, but I think the overall understanding of the wire is lost.
Posted By: geepherder
Date Posted: December 10, 2006 at 5:35 PM
The illumination wire gets 12 volts whenever the parking lights are on, and dims the deck's display a predetermined amount. A dimmer wire will dim the display in correspondence with the position of the dimmer switch. A positive dimmer wire will start at 12 volts with the lights on, and eventually reach ground as the dash lights are dimmed to max. A negative dimmer wire does the opposite- starts at ground with the lights on, and reaches 12 volts with the lights dimmed all the way.
------------- My ex once told me I have a perfect face for radio.
Posted By: tillithz
Date Posted: December 11, 2006 at 10:50 AM
thanks for your time, I am seeing something called PWM, pulsed width module. I think this is going to be a little different then a simple pot. What do you know of this PWM?
Date Posted: December 11, 2006 at 9:03 PM
Honestly, you probably know more about it than I do. However, if you tried to hook up a pulsed signal to the dimmer wires on your head unit, the display would probably appear to be blinking.
