a/v system info please...
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8733
Printed Date: June 01, 2024 at 2:47 PM
Topic: a/v system info please...
Posted By: princestfu
Subject: a/v system info please...
Date Posted: January 28, 2003 at 8:07 PM
hi, i have a 95 nissan altima, and currently have a pioneer mp3 HU, mb quartz component system in da front, and sony xplod's in the rear. the speakers are hooked up to a rockford fosgate 80o watt amp. i'm buying a solobaric L7 15" sub and a power acoustic 1200 watt amp. i also wanna add 2 lcd screens on my sun visors wif a tv tuner and a ps2 so i could watch dvds also. i wanna noe wuts da best way to run everything and wut other stuff do i need because i heard that i need sum kinda amplification so i could run signal to the 2 lcd screens. but wut about da audio ? do i use Y rca connectors to run to da amp ? danx for the help.
Posted By: Velocity Motors
Date Posted: January 28, 2003 at 11:07 PM
You will need a power converter for the PS2 system and then you will need an FM modulator ( unless your Pioneer deck has audio inputs ) for the sound from the PS2. You will need to hook up the FM modulator RCA's to the amplifier that has your speakers attached to it and use Y adaptors to split the signal into the amplifier. If you are using the Pioneer deck then all you need to do is tie into the RCA inputs if available.
------------- Jeff
