Tweeters as speakers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88557
Printed Date: June 06, 2024 at 7:25 PM
Topic: Tweeters as speakers
Posted By: bigste925
Subject: Tweeters as speakers
Date Posted: January 07, 2007 at 11:42 PM
I know the subject line doesnt make much sense however what I want to do is to is to use tweeters as either a: a center channel or b: to play the sound of my nav since my set up is using a seperate nav screen that I can output the sound from. I had considered just using the Clarion Center channel that is a 1/2 din unit for the nav speaker but I am using the JVC AVX2 for the source and since it has a center channel output I want to take advantage and get the best sound I can. Let me know what some of you would do in this situation.
Posted By: DYohn
Date Posted: January 08, 2007 at 10:14 AM
Well, a tweeter IS a speaker, of course... but to answer your question no, in general that's not a good idea.  Tweeters are designed to function (generally) no lower than about 2KHz.  Most center channel information, and certainly most Nav information, requires normal human speech reproduction, the majority of which lies between about 200 and 3000Hz.  A tweeter would not be able to reproduce most of this range.  You need a midrange speaker.
Posted By: ricoshay
Date Posted: January 08, 2007 at 12:09 PM
I second that. In addition a tweeter would probably blow within weeks.
Posted By: j_darling2007
Date Posted: January 08, 2007 at 4:03 PM
https://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-550
Here is the smallest mid-range I could find.  It may work depending on the application / installation
There are 3 kinds of people in the world, those who can count and those who can't
