2001 Chevy Tahoe Head Unit Removal
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88625
Printed Date: May 28, 2024 at 8:44 PM
Topic: 2001 Chevy Tahoe Head Unit Removal
Posted By: tbird2340
Subject: 2001 Chevy Tahoe Head Unit Removal
Date Posted: January 09, 2007 at 7:18 AM
I have a friend that asked me to install some type of XM radio FM modulator on his Tahoe.. Before I have him come over I just wanted to see how the head unit comes out.
Does it need a special tool? Take long?
Thanks!
Posted By: xtremej
Date Posted: January 09, 2007 at 8:21 AM
NO special tools, should take you 5 minutes to remove. Remove the outer trim bezel it, tilt steering wheel down put shifter in L1 and remove trim panel. should be 3 7mm screws holding it in.
Posted By: xtremej
Date Posted: January 09, 2007 at 8:23 AM
Tell your friend you need a torch to remove it, I love using that one haha!!!
Posted By: outtaluck72
Date Posted: January 09, 2007 at 8:36 AM
or tell him that the front seats need to be removed. you always get weird looks on that one.
Posted By: sparkie
Date Posted: January 09, 2007 at 7:20 PM
Actually the radio isn't screwed in. Use the tilt lever to lower the steering column to the lowest position and pull the trim panel that surrounds the radio, climate controls, gauges and air outlet ducts rearwards to release all the clips. Gently squeeze the portion above the steering wheel down to clear the dash above the gauges as you pull it rearwards and up. The radio has a slider bracket on either side of it. Squeeze each one while pulling the radio out. They are spring loaded. It takes only seconds to get these radios out.
------------- sparky
Posted By: xtremej
Date Posted: January 10, 2007 at 8:13 AM
My bad, thinking of an s-10 that we just worked.
Posted By: Velocity Motors
Date Posted: January 10, 2007 at 8:56 AM
You will need a special installation kit for this vehicle. Metra and Scosche both have one for this truck.
------------- Jeff
Date Posted: January 10, 2007 at 9:50 AM
A special kit to install the SIRIUS fm direct adapter?? I thought it just plugged into where the antenna went and then the antenna plugged into it?
Posted By: xtremej
Date Posted: January 10, 2007 at 11:04 AM
You may need antenna adapters for that. Gm has the small plug and the sirius direct fedd fm mod.'s have the big plug input. They make kits that will cover the swap, metra or scoshe.
