run remote wire with power?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90167
Printed Date: June 16, 2024 at 10:51 PM
Topic: run remote wire with power?
Posted By: iv4n
Subject: run remote wire with power?
Date Posted: February 07, 2007 at 3:01 PM
I have read that u should run the remote wire with the RCA cables, and in the opposite side u run the power cable, but i have searched and i need to run the remote cable with the power cable, will it create any noise signal or something? because i will have then to buy a longer remote cable... so the signal RCA cables will run alone.
Thanks for the help.
Posted By: DYohn
Date Posted: February 07, 2007 at 3:05 PM
You are OK.
Posted By: warpedimage3
Date Posted: February 07, 2007 at 10:58 PM
as long as you dont run power and rcas down same side you should be fine.
