line output converter to a pioneer 6cd
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90380
Printed Date: May 21, 2026 at 11:09 PM
Topic: line output converter to a pioneer 6cd
Posted By: meggie418
Subject: line output converter to a pioneer 6cd
Date Posted: February 12, 2007 at 9:42 AM
I'm trying to install an amplifier and subs in my 01' Ford Explorer Sport. It has a factory Pioneer 6 cd changer in the dash, so I didn't want to put in an after market radio. I purchased a line output converter but I'm not sure how to hook it up to the existing radio.
"When life give you lemons...you hit dem wit da bat"
Posted By: godblessdremil
Date Posted: February 12, 2007 at 10:15 AM
The way a LOC works is it converts speaker signal into a pre-amp signal. To install the Loc Just connect one series of wires to the left speaker and one to the right. The one with a black stripe is usually the negative for the speaker and the solid color the positive.(They will share that color). Simple.
Date Posted: February 12, 2007 at 10:23 AM
The problem is I don't know what color the wires should be coming out from the radio. I also need to find the remote wire.
