rear view camera for rear view mirror
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93711
Printed Date: May 11, 2024 at 9:02 PM
Topic: rear view camera for rear view mirror
Posted By: 410440
Subject: rear view camera for rear view mirror
Date Posted: May 08, 2007 at 2:10 AM
so basically i want to install my rear view camera, and use my screan as a rear view mirror, i know there is alot of beef with having "video" played while driving, what are the 12volts thoughts on having the rear view camera on all the time?
------------- Matthew Robertson
Senior Installer
Best Buy Deerfoot Meadows
Calgary, AB, Canada
Posted By: soultinter
Date Posted: May 08, 2007 at 10:09 AM
It wouldn't be running all the time if you are using it properly b cause you would normally hook it up to the reverse wire so it only comes on when the car is put in reverse.
Posted By: kirktcashalini
Date Posted: May 08, 2007 at 10:41 AM
No, I believe he is talking about using a camera and a small monitor in place of a rear view glass mirror. essentially it would be the same thing, but digital. It makes sence to me in the application such as a panel van or other vehicle where you really have limited or no rear view mirror visibility, however, in a vehicle where you do have vision it would seem dumb. cant beat the framerate and clarity of the human eye.
------------- 99 Blazer LT. Yellow Top. Big 3. Infinity Kappa Speakers All Around. Jensen CD/DVD flip out. 2 Infinity Kappa Perfect 12DVQs powered by a Alpine PDX600.1 (in one custom box, building a FG box)
Posted By: 410440
Date Posted: May 08, 2007 at 7:57 PM
I just think it would be cool to do, im not asking for anyones permission to do this, im simply asking for an opinion, or a comment or if someone on here has done this already. ------------- Matthew Robertson
Senior Installer
Calgary, AB, Canada
Posted By: Ween
Date Posted: May 08, 2007 at 9:25 PM
hi, yes, done something similar... put a somewhat large flipdown screen in an Escalade, which when down pretty much blocked the view of the interior rear view mirror. placed a camera pointed out the rear window (up high) which was connected to a small monitor mounted high up by the rear view mirror. mounted a switch in the flipdown, which when opened/released, triggered the monitor via the reverse lead input. so yes it can be done. mark
