2 devices one wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94917
Printed Date: June 01, 2024 at 10:19 AM
Topic: 2 devices one wire
Posted By: hamzter
Subject: 2 devices one wire
Date Posted: June 18, 2007 at 10:42 PM
I am using one 18/2 SJO cable. I will attach 2 molex connectors to power up 2 different devices. The length of the 18/2 SJO cable is about 8 feet plus or minus 6 inches. So basically both devices would be running off of one 18 gauge cable. Does anyone see a problem doing this? Any noise issue...? Both devices are very low current devices with their own fuses in line.
I can't see any reason why it would be a problem, but I want to get a second opinion.
thanks,
------------- Mark "Hamzter" Cinense
1991 Infiniti G20 w/JDM SR20DE
Eclipse CD8445
MTX Thunder 684
Polk DB6750
Polk DB6500
Optima Red Top in the Trunk
Posted By: haemphyst
Date Posted: June 18, 2007 at 11:02 PM
No, that'll work fine...
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
