rear deck wood ring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94976
Printed Date: June 06, 2024 at 4:57 PM
Topic: rear deck wood ring
Posted By: hamzter
Subject: rear deck wood ring
Date Posted: June 21, 2007 at 8:53 AM
just wanted to find out what you all thought about putting a wood ring for rear deck speakers.
I am putting a set of Polk DB6500 in my rear deck and was not sure if it would be beneficial to build a set of 1/4" rings for the 6.5s.
What do you all think?
------------- Mark "Hamzter" Cinense
1991 Infiniti G20 w/JDM SR20DE
Eclipse CD8445
MTX Thunder 684
Polk DB6750
Polk DB6500
Optima Red Top in the Trunk
Posted By: hustlin247
Date Posted: June 21, 2007 at 10:54 AM
That's what Haem did in the doors of his Civic. Looked pretty nice but I'm not really sure what the accoustic reasoning behind it was.
------------- '94 Ford Explorer / Kenwood KVT-815DVD / RF Power T1682C 6x8 (all doors) / RF Power T10001 / 12" Kicker L5 (x4) / Optima Yellow Top Battery
Posted By: hamzter
Date Posted: June 21, 2007 at 10:57 AM
cool...
that is what I am trying to find out here. I did some rings for a 6x9 kicker sub, but could not tell if there was a difference in the sound quality.
My rear deck is treated now(dynamat), but I am not sure if adding a medite ring will help or not.
Eclipse CD8445
MTX Thunder 684
Polk DB6750
Polk DB6500
Posted By: Benji999
Date Posted: June 21, 2007 at 12:36 PM
hamzter wrote:
cool...
It should help, I have done it on all of my speakers along w/ sound deadener. I am a firm believer that your equipment is only as good as your install, so every little bit helps.
Posted By: hamzter
Date Posted: June 21, 2007 at 12:38 PM
well, I will build some rings today, since I will be cutting wood... I might as well.
thanks, ------------- Mark "Hamzter" Cinense
Eclipse CD8445
MTX Thunder 684
Polk DB6750
Polk DB6500
Posted By: Benji999
Date Posted: June 21, 2007 at 12:50 PM
no prob man, what type of wood will you be using?? long story short, please stay away from particle board.
Posted By: haemphyst
Date Posted: June 21, 2007 at 1:25 PM
I did it for spacing... No acoustic reasoning at all! ROFL YOU try putting Adire Extremis 6.8's in the door of a Civic!
Acoustically, I am sure there is SOME benefit, but the doors still need quite a bit more mass to be really damped perfectly (the panels still vibe a bit) but I am pretty sure there was some affect on the system quality! ------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: hamzter
Date Posted: June 21, 2007 at 2:10 PM
for dampening the door panel, I fiberglassed the non-exposed side and then sprayed some dacron to it.
it sounds like a different door now... and it's much stiffer too.
I am going to use 1/4" hardwood, like the stuff pegboard is made of WITHOUT the holes.
Eclipse CD8445
MTX Thunder 684
Polk DB6750
Polk DB6500
