amp, 04 f-250
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95466
Printed Date: February 12, 2026 at 1:51 PM
Topic: amp, 04 f-250
Posted By: ranchorey
Subject: amp, 04 f-250
Date Posted: July 09, 2007 at 4:12 PM
I am going to install an MTX Thunderform enclosure in my F-250. Of course I need an amp to go with it. What I need help with is ... where do I run the blue remote wire to? I had a system in my 04 F-250 and the fool ran the wire into the fuse box which I dont think was wise. So do I need to pull out my radio and find the blue wire there? Any ideas are welcome. Thanks
------------- King Ranch
Posted By: sarcomax
Date Posted: July 10, 2007 at 11:53 AM
factory or aftermarket radio?
Date Posted: July 13, 2007 at 2:48 PM
factory
Posted By: audiomaninc
Date Posted: July 14, 2007 at 1:25 PM
Yank the factory radio and find the pink wire in the factory harness. This wire is the radio accessory wire, and turns the radio on when you turn the key on. This wire will test +12V with the key on and nothing with the key off. Connect your blue remote wire to this wire. Hope this helps!
------------- 2003 Dodge Neon R/T
Alpine CDA9813, RF T2000.1bd, RF T162S, RFT142C, RF T600.4, RF T215D4
140.7 @ 28Hz
