new sub and amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95527
Printed Date: February 11, 2026 at 11:07 AM
Topic: new sub and amp
Posted By: theduckslayer87
Subject: new sub and amp
Date Posted: July 11, 2007 at 9:05 PM
Hello i had a couple questions on installing a new amp and sub. Right now i Have a soild audio ms26 800 watt amp pushing 2 8" mtx's in a truck box. i want to replace them with a kicker zx400.1 mono channel amp pushing 1 of the new kicker comp vt (shallow mount sub). I reall don't know much of anything when it comes to car audio but i wanted to know if that sub, amp combo was good. I also wanted to know when im replacing the amp, can i just pull the cords outta the old amp and replace them the same way into the new amp. and run the same cord that was running into the 8's to the new 12". I dont know any thing about ohms but i was told to wire it this this https://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=42 option 1.  Any help would be great. thanks.
- Tony
Posted By: stevdart
Date Posted: July 11, 2007 at 9:47 PM
Use the 2 ohm wiring diagram for your dual voice coil 4 ohm sub as was suggested.  Your Kicker amp will output into a 2 ohm load, and you can find the output watts rating in the literature.  You should be able to simply unplug the old amp and plug into the new one.  Same thing with speaker output wiring.  Check to be sure your power wire and fuse are adequate for the new amplifier.  You should have at least 8 gauge or preferably 4 ga. running to the amp with the appropriate fuse near the battery.  Fusing requirements can be found using https://www.the12volt.com/info/recwirsz.asp  Ground wire from amp to chassis floor pan must be at least as large as the power wire.
For good info on ohms and how all this stuff works, read https://www.bcae1.com
Date Posted: July 11, 2007 at 10:01 PM
Do i get the 4 ohm or 2 ohm kicker sub?
Posted By: stevdart
Date Posted: July 11, 2007 at 10:14 PM
I don't know.  At first I thought this was a dual voice coil sub by the diagram you included as part of your post, but when I looked it up on the website it looks like it comes as either a single 4 or single 2.  You want a final impedance of 2 ohms.  The ZX400 amp puts out 400 watts into 2 ohms and that is what this sub is rated for.  If this is a SVC sub, choose the 2 ohm version.
Posted By: jmelton86
Date Posted: July 11, 2007 at 10:34 PM
You already know to get the 2ohm sub.
BTW, 12volters, this is a new member from Yahoo!Answers. A recruit, if you will. Thanks for joining the pros, theduckslayer87
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Date Posted: July 11, 2007 at 10:37 PM
theduckslayer87, why did you choose the CVT anyways? Is space an issue here?
Big3 in 1/0G
1/0G to GTO14001
Date Posted: July 11, 2007 at 11:53 PM
yea its a hugh issue, i think a shallow mount is the only one that will fit. i also have 10 gauge is that a big deal? is that sub not that good?
Posted By: sarcomax
Date Posted: July 12, 2007 at 5:24 PM
I have one of those subs on display where I work and it sounds pretty good as far as the shallow mounts go. (better than the bluedot sitting next to it at least). The ten gauge wire has to go though. Check out the wiring guide link that was already suggested to you, and when you buy the new wire, make sure you don't get 8 gauge shielding around 10 gauge wire. stick with monster cable or another well known ( for wire ) company and you will be all right.
Date Posted: July 15, 2007 at 2:24 AM
ok i'll try to get some 8 gauge wire
