troubleshooting on kicker kx850.4?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95659
Printed Date: February 09, 2026 at 6:32 AM
Topic: troubleshooting on kicker kx850.4?
Posted By: qwikrex
Subject: troubleshooting on kicker kx850.4?
Date Posted: July 16, 2007 at 5:53 PM
Hi All,
I bought a remanufactured Kicker KX850.4 from an online reseller. Upon hooking it up in my vehicle, I had the following symptoms.
I connected everything for 4 channel operation, but when the amplifier turned on, and an audio signal was sent to it, it appeared as though the amplifier was running in bridged (2 channel) mode instead.
The right speaker on amplifier 2 was given FAR too much power, and began smoking. The left speaker on amplifier 1 had the same symptom, but instead blew the fuse on the passive crossover.
Using a digital volt meter between the positive and negative connections of those channels revealed that there appeared to be a dead short between the connections.
After this, the amplifier showed the protection LED blinking.
I've emailed the support team of the reseller, and they are no help. they offered no troubleshooting suggestions, and have basically told me I'm up a creek.
I'd like to know if there are any other tests I can perform to see if I've hooked this thing up incorrectly, or if it's really a manufacture/repair defect and I'm stuck buying a new amp.
Any suggestions that you can provide would be greatly appreciated!
Posted By: i am an idiot
Date Posted: July 16, 2007 at 7:38 PM
Disconnect all speaker wires from the amp, turn it on, and if the protection light still comes on, chances are you have one or more shorted output transistors.
Posted By: qwikrex
Date Posted: July 17, 2007 at 5:32 PM
Just gave it a try with no speaker wires connected, and no RCA's connected, and it still had the same problem.
Looks like that may be the problem.
Assuming that it's not a warranty repair (here's hoping) any guess on what that repair would cost if done by Kicker?
Date Posted: July 17, 2007 at 6:04 PM
I have no idea about their rates,  You could call them,  I am sure they have a flay rate for their repairs.     You should be able to get it repaired locally for about 60 dollars.
Posted By: qwikrex
Date Posted: August 11, 2007 at 12:14 AM
Just wanted to thank you for your help, and let you know that I sent it back to Kicker, even out of warranty, and they repaired it at no cost.
It turned out to be a shorted output transistor as you stated.
Thanks again for the help!
Date Posted: August 11, 2007 at 1:03 AM
Glad to help  and thank you for taking the time to let us know you were able to get it resolved.
