sirius power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96004
Printed Date: May 19, 2024 at 6:51 PM
Topic: sirius power
Posted By: blazncypher
Subject: sirius power
Date Posted: July 28, 2007 at 9:54 PM
Can you just cut the wire for the adapter that plugs into your vehicles 12 volt power supply and wire it up through the switched power and ground on the cars stereo wire harness?
Posted By: i am an idiot
Date Posted: July 28, 2007 at 10:13 PM
Where the wire plugs into the unit, it should tell you the input voltage of the unit. A lot of them are not 12 volt units.
Date Posted: July 28, 2007 at 10:50 PM
yeah i know that, i want to know if i could wire it through the factory harness using the power and ground instead of the cars aux power plug
Posted By: mando2155
Date Posted: July 29, 2007 at 12:01 AM
If its not 12v then no, do not cut off the cigarette plug.
Posted By: rudydapimp
Date Posted: July 29, 2007 at 12:59 AM
newer sirius units have a voltage regulator in the tip. if you screw off the end of it, there is a fuse, and if you fully take it apart, you have the grounds (parts that grip into the plug, larger metal bars) and the tip, which is connected to the spring inside, which needs the 12v. tap into a switched 12v (ignition) and fuse it, connect to the wire connected to the spring. put the other lead to ground.
Date Posted: July 29, 2007 at 1:12 AM
thats the answer i was looking for thank you
