planet audio vx2200d, no speaker signal
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97267
Printed Date: May 09, 2024 at 9:22 PM
Topic: planet audio vx2200d, no speaker signal
Posted By: samuelsteven
Subject: planet audio vx2200d, no speaker signal
Date Posted: September 19, 2007 at 5:24 PM
My amp has been working fine, since it was installed. Yesterday, i turned on the truck and the subs didnt turn on. When i went to go see if the fuse was blown under the hood, it was fine. I looked at the amp, and it wasnt under protect and it had a green light, signaling that all was fine. I checked the speaker out terminals with another loose sub, and im not getting any signal out. What colud this be, and why isnt the protect light on? Im pretty electronic savy and own my own computer servicing shop. Could this be something i could fix myself?
Posted By: i am an idiot
Date Posted: September 19, 2007 at 8:50 PM
Make sure the Master/Slave switch is on master. If that is not it you will need to remove the bottom cover. Only remove the 6 screws nearest the bend in the bottom cover. You need to check for a bad connection where the speaker terminals hit the circuit board. There are 2 large identical inductors near that end of the board. Check for broken legs.
Date Posted: September 20, 2007 at 3:29 AM
I took the back cover off, but didnt see any breaks, but i will post some pictures tomorrow..Thanx
