p8400mp wont turn on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97536
Printed Date: May 14, 2024 at 8:47 PM
Topic: p8400mp wont turn on
Posted By: duoproductionx
Subject: p8400mp wont turn on
Date Posted: September 29, 2007 at 8:09 PM
Installed this head unit couple weeks ago, no issues since. Went to leave tonight, no power. Checked all fuses. All wiring looks good. The fuse on the wiring harness is intact...wth??
------------- 97 Monte Carlo
CDA-9885, PZI Crunch 5 channel,12in MB Quart Premium.
Posted By: i am an idiot
Date Posted: September 29, 2007 at 8:17 PM
Were you having trouble with the display going on and off?
Date Posted: September 30, 2007 at 2:14 AM
I didnt have any problems with it at all before this.
Date Posted: September 30, 2007 at 2:39 AM
Before i get any Generic answers on this, Ground, Switched, Power are all properly working, ALL fuses I am aware of are in tact, the one on the 'Battery' Wire-wireharness, the radio fuse is in tact. The unit has NO power. I am pretty good with electronics but i dont want to rip this open if i dont have to.
This head unit worked fine a few hours before on a trip i went for. Went to go for a trip again and bam nothing. Need some ideas quick, thanks.
Posted By: cartechaudio
Date Posted: September 30, 2007 at 10:30 PM
make sure the constant,switch 12v,and Ground is properly connected. First things first, check for a good ground. A simple bad connection will De-power the unit. IF YOU HAVE TO disconnect the radio and take it to your engine bay. Connect the power/switch together and stick the two pos. to the pos. battery terminal and the ground to the ground terminal. make sure the radio is working under direct connection. it does take a little time but a sure way to figure out the power problem. another thing that im pretty sure you have already done is test the lines with a test light.
Date Posted: September 30, 2007 at 10:50 PM
.....I thought i made it clear that it is not a problem with the power to the unit. At any rate I ran out and bought a CDA-9885, popped it in, no issues. I still want to fix this head unit for a friend to use.
