alpine cda 7995 in 07 accent
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97904
Printed Date: May 06, 2024 at 12:36 AM
Topic: alpine cda 7995 in 07 accent
Posted By: seiken
Subject: alpine cda 7995 in 07 accent
Date Posted: October 12, 2007 at 12:39 PM
i bought this head at a pawn shop, so i doesnt have a manual.
first off i need help figuring out what all the wires are for, i think i know most of them but im pretty new at this. so here is a list of the wires that i have
Black, I think its ground
Red, I think its power
Yellow, with a fuse on it
Pink, it is labeled "IN INT"
Blue, labeled "P.ANT" I think it is for the power antenna, so the remote turn on for the amp should go here
Orange
Blue one with a white stripe,
all the speaker wires are in the form of preamp outputs.   if someone could shed some light on the mystery wires for me i would be greatly appreciative, or point me in the right direction since im not really sure where to look.
next, i am installing this into my 07 accent, (pleace dont waste time insulting the car, i make fun of it more then you possibly could, it's all i could afford and i've had these speakers and amp sitting around for two years waiting to be used and life gets boring at college, i needed a project)   anyway, i can't find a wiring diagram for the car, so help with that would also be appreciated.
Women are like turbos, every kid wants two till he realizes how much trouble one is.
Posted By: tcss
Date Posted: October 12, 2007 at 12:45 PM
Go here, and enter your model number CDA-7995 and get the product manual.
Alpine product support
BTW, that deck is preamp only and has no internal amplifier. You will need to use your amp. It has 3 preamp outputs front, rear and an adjustable sub output all of which should be labeled.
There is no such thing as free installation!
Posted By: seiken
Date Posted: October 12, 2007 at 1:45 PM
outstanding, thanks for that link, no i just need to get a wiring diagram for the car an i will be set.
Posted By: sarcomax
Date Posted: October 17, 2007 at 1:45 PM
Great sig line by the way...
DIRECTWIRE™ WIRING INFORMATION - HYUNDAI / ACCENT / 2007 / Audio
[PRINT THIS PAGE]
Radio 12v red  +  radio harness
Radio Ground black and gray/black  -  radio harness
Radio Ignition green  +  radio harness
Radio Illumination yellow  +  radio harness
Factory Amp Turn-on blue  +  radio harness
Power Antenna pink  +  radio harness
LF Speaker +/- brown - white  +,- radio harness or amplifier
Notes: On the 3 door models, the amplifier, if equipped, is in the passenger side quarter panel.
On the 4 door models, the amplifier, if equipped, is in the passenger side of the trunk.
RF Speaker +/- black - yellow  +,- radio harness or amplifier
LR Speaker +/- red - blue  +,- radio harness or amplifier
RR Speaker +/- orange - green  +,- radio harness or amplifier
posted_image
Interface Module:Category:
Immobilizer Bypass
Required:
No
Type:
N/A
Part #: N/A
Notes:
posted_image
Smart Starter Kill Relays: Not Available
posted_image
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
