advice on my future system bd1000 + 12s
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98966
Printed Date: May 22, 2026 at 4:37 AM
Topic: advice on my future system bd1000 + 12s
Posted By: solracer
Subject: advice on my future system bd1000 + 12s
Date Posted: November 13, 2007 at 3:36 PM
Ive got an old school BD1000
Im looking to buy 2 12" Eciipse SW7200's
From what research Ive done, and used come box calculators I should give each chamber .86 cu ft. ,and it would be tuned to 42htz. (sealed)
does this sound right?
Its going in the back of a 92 prelude.
Whats the best way to wire these up to get max power to them?
Also, would it be a waste of money to get the 8200's instead?
Thanx in advance!
Chris
Posted By: solracer
Date Posted: November 15, 2007 at 5:54 AM
anyone?
Chris
Posted By: coppellstereo
Date Posted: November 15, 2007 at 9:51 AM
I had an 8000 series titanium woofer - I LOVED it. I bought my ex a 7000 series aluminum, it was great too. Deep and clean bass. The output was greater from the 8000, but it was power hungry. I had one 12" on a 1200w amp, it loved it. I bet you could run 2 of them on your BD. Is the amp 1 ohm stable?
Posted By: solracer
Date Posted: November 15, 2007 at 8:45 PM
yes... 1000 watt rms, and max is ?????? @ 1ohm
Chris
Date Posted: November 15, 2007 at 10:34 PM
I ran ONE 8000 series woofer and loved it. It sounded better to me than any of the other subwoofers I heard in the streets. If you can afford 2, you will love it! No question about it.
Posted By: solracer
Date Posted: November 16, 2007 at 5:38 AM
why is the 8200 a SVC and the 7200 a DVC?
and since the 8200 is an SVC, how the hell do I get enough power to 2 of them? Seems I could only go 2 ohm....right?
Chris
Date Posted: November 16, 2007 at 12:37 PM
The 8200 is power hungry, I would anticipate most users running each woofer on its own amplifier.
2 SVC woofers in parallel will yield a 1ohm load for your amp. You will spend quite a bit trying to find an adequate amp that is 1ohm stable.
With the bd1000.1 (1000w x1 @2ohm) I would run ONE 8000 series or TWO (2ohm) 7000 series woofers with the coils in series/parallel.
If you are set one having 2 woofers, then go with the 7000 - you wont be sorry.
