1986 mercedes 560 sel radio wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99052
Printed Date: May 21, 2026 at 1:30 PM
Topic: 1986 mercedes 560 sel radio wiring
Posted By: osirisguy
Subject: 1986 mercedes 560 sel radio wiring
Date Posted: November 16, 2007 at 1:05 AM
The other day I was looking for the radio wiring colors for a 1986 Mercedes-Benz 560 SEL with a Becker radio. After using most of the resources on hand I could not get the wiring so I wrote down the wire colors. Hopefully someone else will be able to easily find this if it is ever needed.
Constant = RED / White
Switch = BLACK/ White
Ground* = Black and/or Brown
Antenna Power = Blue
Illumination = Gray/Purple [NOTE: there are actually two of these wires]
Left Speakers
+ = RED / Black
- = Black
Right Speakers
+ = GREEN/ Black
- = Black
*There were two ground wires. The black wire seemed to be a second ground, or ground for something else. The ground for the radio was the Brown wire.
From what I remember the car's stereo was in stereo, that is there was only left and right, no front or rear connections. Again I am going from memory but the speaker locations were on the front dash, under the windshield, the rear deck, and I believe there was another pair, however I can be confusing two cars.
I don;t consider this information 100% accurate so please double check these wires. If anyone can make or knows of corrections/suggestions, please comment so I can edit, or edit yourself this information
Reeces Pieces,
Joe
"God invented man, and man invented the metric system."
- Salvador Dali
Posted By: techman93
Date Posted: November 16, 2007 at 10:06 PM
LF Speaker (+)          WHITE
LF Speaker (-)          BLACK
RF Speaker (+)          WHITE
RF Speaker (-)          BLACK
LR Speaker (+)          WHITE
LR Speaker (-)          BLACK
RR Speaker (+)          WHITE
RR Speaker (-)          BLACK
Amp Location          CHECK LEFT IN TRUNK
Radio Security          NO
Audiovox technical
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
