line out converters
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99054
Printed Date: May 21, 2026 at 2:30 PM
Topic: line out converters
Posted By: Thack79
Subject: line out converters
Date Posted: November 16, 2007 at 5:42 AM
I have to 2 install two line out converters (a two channel and a four channel) can I tie all the wires into the front two speakers outputs from the deck. The customer wants to retain the factory radio in a cadillac 2005 sts (bose system). thanks forum.  There will be no speakers hooked up from the radio,  just need the signal to be converted to RCA .  to amp the interior speakers (4channel amp) and a sub (2 channel amp)
Posted By: Velocity Motors
Date Posted: November 16, 2007 at 7:57 AM
Use the RE-Q module for what you want. Also, does the 4 channel amp have a expandable input option on there where you can have one set of RCA inputs and it will pass through the signal to the rear channels without having to add another set of RCA's ?
The RE-Q takes low level signal and outputs a pair of front RCA's and also a set of designated subwoofer outputs. I've used these before on newer GM's and it works great.
Posted By: Thack79
Date Posted: November 16, 2007 at 8:49 AM
the 4 channel is the eclipse 4100 and i believe it does have the pass thru. forgot all about that. thanks man.  Ima tie the 4 channel LOC to the front speakers and line out to the sub amp for now. But where can I advise this guy to get this "RE-Q module"??
Date Posted: November 16, 2007 at 9:41 AM
RE-Q can be purchased at any Mitek dealer ( MTX ). They retail for about $ 100-$ 150 depending on where you are located in the country.
Posted By: Thack79
Date Posted: November 16, 2007 at 9:49 AM
greatly appreicated. thanks.
