Does anyone have a wiring diagram for the factory amp two connectors on a 2006 Tundra? I want to hook up an after market amp and i don't know if buying a wiring harness will work. Anyone have any ideas?
-PJ
If you are putting in an after market amp to run what? Speakers or subwoofers? You can get at the wires at the back of the radio and use a high level input on an amp or use a LOC (line out converter), or you can create rca off the back of the radio to the amp low input. It is depending on where you are accessing the wires. You also have to check the turn on wire to see if it puts out 12 volts or less. If it puts out less then 12v+ then you need to add a relay for the after market amp. If running amp to speakers you may want to run new 18 - 16 awg wire into the doors.
Battery RED OR RED / GREEN (+) RADIO HARNESS
Accessory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Amp Turn On BLACK/ RED (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) VIOLET
RF Speaker (+) GREEN
RF Speaker (-) BLUE
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
techman is correct relays are "voltage boosters" if needed you would wire as follows ......using a 30 amp spdt relayy connect teminal 87 to constant 12 v positive with a fuse rated to the total of additional accs. added and components you need to turn on connect terminal 85 to ground terminal 86 to remote turn on on wire from hu and terminal 30 to each accessory with proper fuse rating.
