dvc, svc, series, parallel
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99199
Printed Date: May 15, 2024 at 1:37 AM
Topic: dvc, svc, series, parallel
Posted By: standbackimapro
Subject: dvc, svc, series, parallel
Date Posted: November 20, 2007 at 5:36 PM
Can someone please Explain how to tell the differnce between a svc, dvc.. and the difference between series, paralell, independant and why they need to be wired that way?
Like if i had 2 subs, a mono 1 channel amp.. why couldnt i have 2 + wires from the amp + going to each subs +,  then 2 - negative wires going to each - of each sub.. why would i have to  run the positive to one subs + then the negative of that sub to the other subs positve then the negative of the other sub back to the amp negative?
Posted By: i am an idiot
Date Posted: November 20, 2007 at 6:00 PM
It all depends on the minimum possible ohm load of your amp and the impedance of your speaker.    If you have an amp with a minimun load of 4 ohms and you have 2   8 ohm speakers, the way you suggested would be the proper way in that situation.
Now the same amp and 2 ohm speakers.  2   2ohm speakers connected that way will yield a 1 ohm load.  Wired in series they will yield a 4 ohm load.  Your amp will be happy there.   Not so happy at 1 ohm load.
Posted By: stevdart
Date Posted: November 20, 2007 at 9:25 PM
That is a description of parallel wiring, where all connections are of the same polarity.
And that is a description of series wiring.
(...and then ditto what I am an idiot said.)  Parallel and series wiring schemes create different impedances.  See the calculators in the left column under "Parallel and Series Calculators" to try out a few scenarios.
I'm not sure what you mean by "independent" wiring, but I'll assume it refers to your first description.  Parallel is parallel, whether the wires go separately from each sub to the amp or whether the subs are connected to each other in same polarity.  The important common value is that the amp positive connects only with sub(s) positive and likewise with negative.
Posted By: coppellstereo
Date Posted: November 21, 2007 at 9:27 AM
I like JL's diagrams and ease of use:
https://mobile.jlaudio.com/support_pages.php?page_id=145
