lights dim when doors lock?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99815
Printed Date: March 14, 2026 at 6:16 AM
Topic: lights dim when doors lock?
Posted By: lanceam24
Subject: lights dim when doors lock?
Date Posted: December 09, 2007 at 5:21 PM
in my 1996 mazda protege, my lights dim because of my sound system. but the other day i noticed my dome light dims whenever i lock or unlock my doors from the electric door button. my battery has 450 cold cranking amps so i was thinkin about gettin an optima red top. i have upgraded the negative battery to ground wire of the big 3, but my alternator is so hard to get to i will probably not do alt. to batt. positive. what should i do?
Posted By: dwarren
Date Posted: December 09, 2007 at 6:02 PM
Have you done a load test on the battery lately? You may simply have a bad battery.
Date Posted: December 09, 2007 at 6:13 PM
i did a while ago because i got a new alternator, and it was just fine. but that was maybe 2 months ago. maybe i should go to autozone
Posted By: dwarren
Date Posted: December 09, 2007 at 6:15 PM
Can't hurt, and can usually save a headache in the future.
Posted By: haemphyst
Date Posted: December 09, 2007 at 10:01 PM
I have an Optima Red Top, with a 200A alternator, 2F worth of cap in the trunk, and my dome light is LED. I still get dimming.
My wife's brand new Fit, completely bone stock, and brand new off the showroom floor had the same thing occur from the day I drove it home. Even to this day, if the headlights are on, and we are driving down the street, if I bump my lock tab down, and all the rest of the locks go with it (which they do) even the headlights will dim a little bit, and the engine is RUNNING!
I don't personally believe there is anything wrong with any part of your electrical system at all, including the battery. The door locks are solenoids, which are a VERY high inrush current, and this is (generally speaking) a normal situation, to see a little bit of a dimming.
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Date Posted: December 09, 2007 at 10:13 PM
o ok then. one more question: i upgraded the negative battery to chassis with 4awg wire and now my headlights are VERY dim. i did not remove the factory wiring and i did not sand the paint to bare medal under the bolt i attached it to. any idea why?
Posted By: aznboi3644
Date Posted: December 09, 2007 at 10:15 PM
upgrade your big three if you havent
