2005 cts v sub add on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99817
Printed Date: March 14, 2026 at 4:50 AM
Topic: 2005 cts v sub add on
Posted By: kauzenkaos
Subject: 2005 cts v sub add on
Date Posted: December 09, 2007 at 6:23 PM
i have a 2005 cts-v with bose audio system I'm trying to find a wiring diagram or any information that would help with a zapco amp install. I'm looking to use the symbilink cable but am unsure if the sub channel will provide a good enough signal for the amp. i took the amp out of my 2003 acura which also was running a bose system but i was able to install the symbilink cable directly into the right and left channel speaker wires in the rear deck  my cts only has a sub in the rear deck. my other question is if the sub channel signal is strong enough is it ok to hook both left and right channels on the symbalink cable so i can bridge my amp?
Posted By: tedmond
Date Posted: December 09, 2007 at 11:25 PM
Battery RED / WHITE (+) RADIO HARNESS
posted_imageAccesory  posted_image
posted_imageGround BLACK/ WHITE (-) RADIO HARNESS
posted_imageIllumination  posted_image
posted_imageDimmer  posted_image
posted_imageAmp Turn On VIOLET (DATA) RADIO HARNESS posted_image
posted_imageLF Speaker (+) TAN posted_image
posted_imageLF Speaker (-) DARK GREEN
posted_imageRF Speaker (+) LIGHT GREEN posted_image
posted_imageRF Speaker (-) LIGHT GREEN
posted_imageAmp Location THE AMPLIFIER IS LOCATED BEHIND THE TRIM PANEL ON THE LEFT SIDE OF THE CARGO AREA.
posted_imageSteering Cntrls OPTIONAL posted_image
posted_imageSpeed Cntrl YES
posted_imageRadio Security YES
Date Posted: December 10, 2007 at 1:02 AM
tedmond what am i looking at ? first off im looking for a complete diagram or at least a diagram that deals with the rear speaker channels or possible some install advice from someone who has some experience with symbilink installs.
Posted By: 01trublugt
Date Posted: December 11, 2007 at 10:11 AM
What you are looking at is the wiring diagram for the back of your factory radio.
If you are trying to run a sub off of your factory system the best way to do it would be to get a line output converter and tap into the Front speaker wires comming out of the radio. Usually the wires comming off of the amps are too much voltage for a line output converter.
You can tap the front wires for the LOC, run a set of RCA's from the LOC to the symbilink, then run the symbilink cable to the sub amp.
Date Posted: December 22, 2007 at 7:13 PM
well i just got around to doin the install on the amp and i have another qeustion about this diagram on the right speaker channel which light green is is the positive and which light green is the negative or should i guess
