2002 dodge ram speakers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99846
Printed Date: March 14, 2026 at 4:50 AM
Topic: 2002 dodge ram speakers
Posted By: longhornman585
Subject: 2002 dodge ram speakers
Date Posted: December 10, 2007 at 1:12 PM
i have a 2002 dodge ram 1500 single cab...2dr
i am redoing the sound system in my truck and i cant figure out how to get to the speakers in the back of the truck behind the seats... any help?
Posted By: techman93
Date Posted: December 10, 2007 at 11:46 PM
Some of those trucks you may need to remove seat and panels to get to them. I know in a couple Chevy P/U's I had done I had to do this.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Date Posted: December 11, 2007 at 12:40 AM
yea..i know i need to remove the panels..but i am having a hard time doing this..is there a trick to it or pictures or something?
Posted By: howmuchlonger
Date Posted: December 11, 2007 at 9:57 AM
remove the sill plate
pull the weather stripping
get a pannel tool or some sort of lever in the gap that the weather stripping occupied
PRY
the pannel is held in w/clips
2 screws per speaker
if there are speakers there now you are all set, if not you may need to wire
You may have an issue w/depth on the front 6x9 speakers fyi
Test it w/your meter!!!
Date Posted: December 14, 2007 at 5:10 PM
i have bought a new set of speakers for my single cab truck.. I havnt figured out how to get the front door panels off after i take off all the screws..i think it has something to do with the window thing to roll down the window..i dont have automatic windows so i cant figure out how to get the window turner off.. ne help of adivce?
Posted By: tcss
Date Posted: December 14, 2007 at 5:18 PM
There is a small cotter pin between the handle and the plastic disc behind the handle. There is a special window clip removal tool that makes it easier, but I have done it with a screw driver. This cotter pin is nicknamed an "Oh Jesus clip", because it will pop off the door and fly accrossed the room while you yell OH JESUS! Because you never find it .............
There is no such thing as free installation!
Date Posted: December 15, 2007 at 11:40 AM
so how do i locate this pin and remove it
Posted By: tcss
Date Posted: December 15, 2007 at 1:33 PM
The window crank should have a small plastic disc between it and the door. The clip is between the two. It will be a "C" shape. Separate it on the open side and pry it off.
Date Posted: December 20, 2007 at 8:52 PM
I cannot figure out what tool i need to remove the seat belt bolt. I have a 2002 dodge ram 1500 single cab.
Date Posted: December 21, 2007 at 8:16 AM
I have bought speakers to replace behind my seat. I have a 2002 dodge ram 1500 single cab. I cannot figure out how to get the bolts off the seatbelt. Does ne one know what kind of tool i need?
Posted By: crewwzin
Date Posted: December 21, 2007 at 8:56 AM
If I remember correctly, its a T55 Torx bit. Good luck with it.
I'd rather be in the boat with a drink on the rocks, than in the drink with a boat on the rocks!
Date Posted: December 21, 2007 at 2:19 PM
thanks !!
Posted By: haemphyst
Date Posted: December 22, 2007 at 7:41 AM
Huh... See, we ALL learn someting new here everyday. I never knew that was called the "Oh Jesus Clip". I always called it the "ǻω, ςђіŧ" clip! Thanks for setting me straight, Bob! (Always forward, never straight!)
Date Posted: December 30, 2007 at 12:11 AM
it is actually not a t55.... i still cant figure it out.. ne help?
