circuit: adjustable negative or low pulse
Forum Name: Motorcycle Electronics
Forum Discription: Installing Stereos, Alarms, Remote Starters, Lights, Garage Door Openers and other electronics on motorcycles.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108936
Printed Date: May 05, 2026 at 7:46 PM
Topic: circuit: adjustable negative or low pulse
Posted By: petergun
Subject: circuit: adjustable negative or low pulse
Date Posted: November 15, 2008 at 1:04 PM
Hello, I'm trying to duplicate negative pulses from a motorcycle speedometer's reed switch. This low pulse was roughly 4 X a second & signaled my directional module to cancel directional flash output. My new speedometer has no switch. I would like to trick the module with maybe a directional flash: (high pulse) to start a series of unrelated negative pulses that I would feed in as one lead to the reed switch input. So simple it's complicated! Ideas appreciated.
------------- A mind is a terrible thing to waste
Posted By: dualsport
Date Posted: April 12, 2009 at 3:25 AM
Been a while- still looking to do this?
Should be easy enough with an IC, resistor and cap. Schmitt 2 input NAND gate connected as an oscillator by feeding the output back to the input, and the other input coming from the directional signal. When the directional signal is high, the gate will output pulses, and when the signal is turned off, the pulses will stop.
