two electronic problems
Forum Name: Motorcycle Electronics
Forum Discription: Installing Stereos, Alarms, Remote Starters, Lights, Garage Door Openers and other electronics on motorcycles.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111369
Printed Date: May 06, 2026 at 1:23 AM
Topic: two electronic problems
Posted By: kap142
Subject: two electronic problems
Date Posted: February 07, 2009 at 6:34 AM
I am working on a 79 Honda CB750K basket case project that I inherited from another.  As I received it parts, lights etc. missing.  Thus far I have chopped the frame and brought it back to a "near completed" bike.
I have reached the stage that wiring and lighting are my stumbling blocks.  I am using the factory harness.and have run into 2 problems that I seem unable to resolve.  One is going from a 3 wire running light set up to seperate turn signals (meaning seperate from the LED stop/brake/running light).  Change over is to LEDs for all 4 turn signals and second is that every tme I turn the key on I blow a main 30 amp fuse.  I do have open wires all over the place where the last owner cut and removed lights (never to be seen again) but none are grounding.
I do have a wiring diagram but even with it's help I can't figure the turn signal wiring nor how to make them function.  I have replaced the flasher with an electronic flasher but no progress so far.
I have mastered the connection to the rear stop/turn/running light so that's resolved.
Offered help would be greatly appreciated.
Ken
It's 5 O'Clock somewhere
Posted By: ckeeler
Date Posted: February 07, 2009 at 10:56 PM
in cases like yours, i just rip out the entire harness and make a brand new one from scratch the way i want it, but, since i cant do that....can you post the wiring diagram, or e-mail it? that would help anyone here that might want to help you.
Posted By: kap142
Date Posted: February 08, 2009 at 7:28 AM
I ran across one a few days ago, now just need to find it again.
Resolved the ground problem.  I'd pinched a wirewhen I installed a new (used) R side control so it's back to the lighting issue
Posted By: kap142
Date Posted: February 08, 2009 at 7:36 AM
Found the link ref wiring diagram it's www.hondachopper.com/images/cb750k1-wiring-diagram.jpg
Posted By: kap142
Date Posted: February 08, 2009 at 6:41 PM
OK gang forget it.  I guess just dumb persaverience paid off.  Parts eventually fell into place, including the 3 to 2 wiring situation.  Bike is now totally wired and working as it should.  Thanks for the help.
