2000 honda cbrf4 remote start
Forum Name: Motorcycle Electronics
Forum Discription: Installing Stereos, Alarms, Remote Starters, Lights, Garage Door Openers and other electronics on motorcycles.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127396
Printed Date: May 04, 2024 at 9:38 AM
Topic: 2000 honda cbrf4 remote start
Posted By: corb76
Subject: 2000 honda cbrf4 remote start
Date Posted: May 19, 2011 at 5:01 PM
I recently purchased an alarm/remote start specifically for motorcycles. I wanted it for the two way pager alarm but figured since I have the remote I might as well use it.
It seams like a very basic system and the alarm I have already installed. I have all the wire attached for the remote start except for a pink wire and a gray wire. When i push the start button the bike will crank but it won't catch. obviously it has something to do with the unattached wires. The only way I can get it to start is if I turn the key to the on position.
Can anyone please help??!!
Posted By: Twelvoltz
Date Posted: June 28, 2011 at 9:08 PM
Without more information an answer might be hard to pinpoint, but my guess would be that one of those wires (probably pink) needs to go to ignition.
What is the make and model number of the unit? Do they offer it's install manual online, if they don't, can you scan and post it?
The 2000 is fuel injected? If it's not you'll need to pull the choke anytime it's cold.
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: enoxos
Date Posted: June 29, 2012 at 7:36 PM
look, I had the same issue too until I looked the diagram of the my bike.
When you turn the key to acc, there may be another circuit that needs to be energized/completed.
in my yamaha, the circuit was from the computer to the safety relay.
I sued a relay to short these two wires while in remote start and presto
renee
